ᐅ Are there specific adapters available for mounting PAX units to the wall?
Created on: 29 Mar 2015 09:17
Dikakau
Dikakau
29 Mar 2015 09:17
Hello everyone, I am currently looking into wall mounting options for IKEA PAX wardrobe systems and wanted to know if there are any special adapters or mounting materials specifically designed for attaching PAX wardrobe elements to walls.
I am particularly interested in whether IKEA or third-party suppliers offer practical solutions that not only make the installation safer but also help with alignment or protect the wall. Standard brackets or screws are often not ideal, especially when dealing with heavy units like wardrobes.
Does anyone have experience or know of suitable accessories? I look forward to your advice, especially if you have mounted PAX on different types of walls before!
Leland
29 Mar 2015 10:23
Yes, IKEA offers special wall anchors for PAX. These are usually metal brackets with screws that are mounted directly onto the back panel of the cabinet.
You can use regular wall brackets, but the IKEA adapters fit better into the grooves of the back panel. Just check the accessory section at IKEA.
benonon
30 Mar 2015 14:05
Exactly, these wall anchors are not just simple brackets but an integral part of the PAX installation.
It is important during assembly that the back panel, which in PAX is often a thin hardboard, is held securely. The original IKEA adapters fix onto the grooves of the back panel, so the load is well distributed.
To increase safety, I recommend the following steps:
- Before installation, check if the wall type (e.g., concrete, drywall, brick) requires specific anchors.
- For drywall, definitely use heavy-duty anchors; otherwise, there is a risk the cabinet could tip over later.
- Use the correct screws with the IKEA PAX brackets, not just the ones included, as these can sometimes be a bit short.
- Align the cabinet before final fastening and check it with a spirit level.
Alternatively, some third-party suppliers on Amazon or at hardware stores offer modified wall brackets with higher load capacity and sometimes with adjustment options for fine-tuning.
What exactly is the structure of the wall where you want to mount your PAX? This significantly affects the choice of fixings!
Dikakau
30 Mar 2015 18:46
benonon schrieb:
What exactly is the wall structure where you want to mount your PAX?
Thanks for the detailed information! Unfortunately, my wall is made of drywall on a wooden stud frame, so it’s not a solid masonry wall.
This makes me a bit uncertain whether the standard adapters will hold securely or if I should get reinforced anchors as well. I’ve read that PAX doors can be quite heavy and put considerable load on the wall.
Would it be possible to reinforce the mounting points with a wooden board behind the drywall or something similar, or would you recommend using special heavy-duty anchors right away?
Which adapters are compatible with these loads? Are there any experiences with the combination of PAX and drywall construction?
parpeo
31 Mar 2015 11:12
Dikakau schrieb:
Would it be possible to reinforce the fixing points with a wooden board behind the drywall or something similar, or would you recommend using special heavy-duty anchors directly?
Hello! For drywall, it is generally recommended that for heavy loads such as a PAX wardrobe, you either mount directly onto the wood studs by pre-drilling and screwing through, or at least use heavy-duty anchors specifically designed for drywall load-bearing.
Installing an additional wooden board behind the drywall is often only possible if the interior construction was planned accordingly in advance. If that’s not an option, cavity metal anchors or specialized drywall expansion anchors can help.
The PAX-specific adapters from IKEA are well suited for solid masonry walls, but for drywall you should definitely use heavy-duty anchors. These are usually sufficient in combination with the PAX wall brackets if the screws engage deeply enough into the studs.
Another option would be profile rails mounted horizontally on the wall, allowing the wardrobe to hang via adapters. This distributes the load more evenly.
If you like, I can also send you a detailed list of suitable anchor types for drywall.
