ᐅ Are there repair kits specifically designed for Malm furniture?
Created on: 19 Jan 2023 08:12
pinalim6
pinalim6
19 Jan 2023 08:12
Good morning everyone,
I recently noticed some minor damage to my IKEA Malm furniture that I would like to repair myself instead of replacing the entire piece. My question is: are there any specific repair kits or sets designed especially for Malm furniture? So far, I have only found generic wood or furniture repair kits online, but nothing tailored to this series.
I’m particularly interested in solutions that can address common surface scratches and small dents without compromising the furniture’s typical appearance. Has anyone had experience with a repair kit specifically suited for Malm, or can offer advice on the best products or methods to use?
Thanks in advance!
chenValeri
19 Jan 2023 08:34
As far as I know, there are no official repair kits from IKEA specifically for Malm.
I would recommend using a general wood repair kit with wax sticks and filler putty. This works well for fixing small scratches and dents.
Marlenepa
19 Jan 2023 09:47
regarding your question: Officially, IKEA does not offer specific repair kits for Malm furniture. The surface of this series is usually laminated, which makes repairs a bit more challenging.
is actually a good tip.
Surface scratches can often be treated with color-matched wax sticks. For deeper damage, wood glue and minor filler work can help.
I also recommend using light sanding pads and a fine touch-up paint pen in the matching color to seal the repair.
If you like, I can suggest a few brands that work well.
naujon
20 Jan 2023 16:53
Hello pinalim6,
I would like to organize my reply to give you a clear overview:
1. Material of Malm furniture: They are usually made of coated particleboard, which means repairs to the surface need to be done more carefully compared to solid wood.
2. Repair kits:
- There are no kits specifically offered by IKEA for Malm.
- General furniture repair kits (including wax sticks, fillers, and paints) are the best option.
3. Application tips:
- For minor scratches, use color-matched wax sticks.
- For dents: use wood or furniture filler that matches the color of your furniture.
- After repair, always gently sand smooth with fine sandpaper and, if needed, seal with a transparent clear coat.
4. Common mistakes:
- Excessive sanding damages the film surface.
- Using materials that differ too much in color is noticeable.
Summary: There is no special Malm repair kit, but universal furniture repair sets for coated surfaces work well. This way, many minor damages can be effectively fixed.
pinalim6
21 Jan 2023 11:18
Thanks for the tip, that already sounds very helpful. If you could mention some brands, that would be great.
naujon schrieb:
After the repair, always gently sand smooth with fine-grit sandpaper and possibly seal with a clear, colorless varnish.
Could you please explain in more detail how to best sand the surface without damaging the laminate? Is there a specific grit you would recommend? I want to avoid the repair becoming more noticeable than the damage itself.
I’m also interested if you know of any beginner kits that include all the essential materials to properly repair a laminated surface. Buying wax and filler separately seems a bit uncoordinated to me, especially if I am trying this for the first time.
BOMILAN
21 Jan 2023 17:29
I once touched up small scratches on my Malm dressers by simply coloring them in with a colored pencil from the stationery store that matched the wood tone. It worked surprisingly well for minor blemishes.
For larger damages, I used expanding foam and wood filler, then carefully smoothed the surface with very fine sandpaper (around 240 grit). Be careful not to sand too much, or the veneer might tear.
