ᐅ Are there repair kits available for Malm hinges?
Created on: 8 Apr 2020 09:17
FULERA
FULERA
8 Apr 2020 09:17
Are there currently repair kits available for the hinges of Ikea Malm dressers or Hemnes models that can fix common issues like loose or worn hinge mechanisms? Recently, I’ve noticed that the hinges on my Malm dresser don’t close properly anymore and feel slightly loose, which might indicate worn plastic parts or missing small components. Are there repair kits from Ikea itself or other suppliers that allow you to secure or promptly replace the hinges without having to replace the entire hardware? A durable yet straightforward solution would be important to me, ideally involving the replacement of worn parts or fitting screws and small mechanical components precisely.
Matthewt48
8 Apr 2020 09:39
FULERA schrieb:
Are there currently repair kits available for the hinges of Ikea Malm dressers or Hemnes, which can fix common issues like loose or worn hinge mechanisms?
Ikea generally does not sell specific repair kits for Malm hinges, as these are usually treated as replaceable complete hinge units. However, there are third-party suppliers offering spare parts and small repair kits, such as plastic sleeves or springs, which can help with loose hinges.
If the hinges are completely worn out, it is usually recommended to replace the entire hinge. There are many compatible models available from other manufacturers as well.
I would suggest checking specialized online stores for furniture fittings or forums, where links to affordable repair kits are often shared. By the way, you can often order replacement hardware directly from Ikea if you have the correct item numbers.
Sinan-meo
8 Apr 2020 10:06
Matthewt48 schrieb:
Ikea itself does not sell specific repair kits for the Malm hinges
That’s correct. Ikea hinges are typically integrated into their systems and are not designed as separate repair kits.
From my experience with several furniture pieces using Ikea hinges, the problems often come from the plastic dowels in the drill holes or the spring mechanisms. While there are no official repair kits, with some DIY skills, these parts can be replaced quite effectively.
If you are somewhat handy, you can buy matching plastic inserts or metal springs individually and install them. Sometimes using Loctite or a mild adhesive helps when screws or dowels are loose.
On the other hand, the simplest solution is usually to replace the hinges entirely – one screw out, new hinge on, done. Replacement hinges are inexpensive, and the time saved along with the lower effort usually outweighs spending a lot of time repairing the original part.
Repar
8 Apr 2020 10:28
FULERA schrieb:
Are there repair kits for the hinges of Ikea Malm dressers?
Direct repair kits from Ikea are not available.
However, you can order plastic sleeves if they have become worn out, or buy completely new hinges.
Individual repair parts are very rare. Replacement is usually the better option.
Genevieve
9 Apr 2020 11:03
Matthewt48 schrieb:
Third-party suppliers offering spare parts and mini repair kits
That may be true, but which specific source or manufacturer actually provides compatible repair kits? I have researched various stores, but often the spare parts are either too generic or do not fit the Ikea Malm hinges precisely.
I think reliable recommendations or verified user experiences of those who have successfully used a repair kit are missing here.
Aside from that, it would also be interesting to know whether replacing entire hinges is more environmentally sustainable than partial repairs using used or lower-quality components. Just because repair kits exist doesn’t necessarily mean they are a good practical solution.
Matthewt48
9 Apr 2020 14:46
Genevieve schrieb:
I think there is a lack of well-founded recommendations or reliable user experiences here
That’s an important point. From my experience: I haven’t found any official repair kits for the Malm dresser itself, but for so-called “clip hinges” of similar design from other brands, there are repair kits available that include springs, plastic bushings, or adjustment screws.
Personally, I prefer to replace entire hinges, especially when they show significant wear. For example, I often use cabinet hinges from Hettich or Blum, which are compatible and offer better quality.
Whether this is more environmentally friendly depends on the condition of the individual part. If the mechanism is still intact and only a bushing is loose, a targeted repair can of course be more sustainable in the long term. However, you need to find suitable parts, which is unfortunately difficult with Ikea.
