ᐅ Are there quality differences in Ikea Brimnes depending on the year of purchase?
Created on: 23 May 2017 19:43
PARBI
PARBI
23 May 2017 19:43
I am currently considering purchasing a Brimnes dresser from Ikea, but I have come across a question that is a bit difficult to answer: Are there quality differences in Ikea Brimnes furniture depending on the year of purchase?
I have noticed that many Ikea furniture pieces seem to have changed over the years in terms of manufacturing or material thickness. I wonder if this is also the case with the Brimnes series, for example, differences in wood quality, workmanship, stability, or the coatings used.
If anyone has experience with Brimnes furniture from different production years or knows about any changes in manufacturing, I would appreciate the opportunity to exchange information.
It would also be helpful to know if Ikea generally makes such quality adjustments in their product lines and whether they specifically restock or use older inventory.
gaubla
23 May 2017 20:15
In general, it can be said that Ikea regularly makes adjustments to its product lines to optimize costs and production, which sometimes affects material quality and workmanship. Specifically for Brimnes, there are reports that older models (around before 2014) were often built more robustly, using thicker particleboard and stronger joints. Newer models tend to use thinner furniture panels and simpler fittings more frequently.
These changes are mainly aimed at reducing manufacturing costs and can impact durability. However, storage and maintenance also have a significant effect on the lifespan.
If you are aiming for long-term use, I would recommend choosing models with more stable joints and thicker materials – the older production years often offer advantages in this regard.
marix
23 May 2017 21:04
gaubla schrieb:
Newer models tend to use thinner furniture panels and simpler fittings.
I can only agree with that. I own a Brimnes chest of drawers from 2012, which still feels very sturdy and well-made. However, I recently bought the same series as a replacement, and you can clearly notice that the panels appear thinner.
This is, of course, a typical effect with Ikea: prices remain reasonable, but the quality varies slightly depending on when the furniture was produced. If you value durability, it’s worth paying attention to the production year and checking the workmanship in person.
Sometimes, taking a closer look at the screw guides and edges helps as well: older furniture often has a more robust coating and stronger joints.
nixon0
24 May 2017 07:51
If you are unsure, don't buy the latest model; instead, look for clearance items or floor models. These are often built more robustly. Alternatively, try testing them hands-on at the furniture store.
GALEO4
24 May 2017 09:23
I think the whole hype about quality differences at IKEA is often overrated. Sure, there are small changes, but anyone seriously expecting IKEA furniture to be "high-quality solid wood furniture" is going to be disappointed.
PARBI schrieb:
Are there quality differences in IKEA Brimnes depending on the year of purchase?
Yes, but that’s part of the concept: furniture is meant to be cheap, lightweight, and replaceable within a short time. If you want higher quality, you shouldn’t buy from IKEA or you should at least expect what comes with low-cost production.
So, instead of always focusing on the year of manufacture, it’s better to ask yourself: "For how long do I want this piece of furniture?"
laureo
24 May 2017 14:38
As a supplement: In recent years, Ikea has shown a tendency to optimize production toward more efficient manufacturing and material savings. While this can negatively affect material thicknesses, it does not necessarily mean that all newer Brimnes products are of lower quality.
- New joining techniques and modern wood fillers can ensure stability even with thinner panels.
- The painting and edge finishing have been partially improved to maintain the appearance.
Overall, furniture should always be assessed based on the specific product and not solely on the year of purchase. Of course, there are reports suggesting a slightly reduced lifespan in newer models, but these are more likely isolated cases.
