ᐅ Are there Malm furniture options available with higher weight capacity?
Created on: 1 May 2019 08:37
Leon53Hello everyone,
I am currently looking into whether there are versions of Ikea Malm furniture that offer higher load capacities than the usual ones. Specifically, I am interested in dressers and wardrobes from the Malm series, which are very popular but, depending on the model and material quality, are sometimes designed for limited weight loads.
I am therefore seeking versions or possible modifications, either directly from the manufacturer or recommended by users, that allow these furniture pieces to safely support heavier loads without compromising stability or durability. It is especially important to know if there are differences in load capacity between the many Malm variants, and whether different materials or reinforcements are available as standard or as accessories.
Does anyone have experience with this or know of official information? I look forward to your assessments and tips!
Johnathon1 May 2019 09:22Hello Leon53,
regarding your question about whether there are Malm furniture variants with higher load capacity, I can provide some background information. In general, the standard Malm furniture from Ikea, such as dressers and wardrobes, is made of particleboard with a laminate surface, which is sufficient for everyday use but limits the load capacity. The maximum load varies depending on the model and size – a 3-drawer dresser typically supports about 30 to 50 kg (66 to 110 lbs) per drawer.
Ikea does not offer specific “reinforced” versions of Malm furniture. However, there are some tips and tricks that users can apply to increase the load capacity. For example:
1. Reinforcing the back panel: Many Malm pieces have thin back panels attached only with nails, which can be replaced or supplemented with solid wood panels or metal reinforcements.
2. Additional cross supports: Flexible reinforcements like metal brackets or high-quality wooden beams can be added under shelves or drawers.
3. Assembly quality: A very careful and correct assembly, ideally with extra screws and special anchors, greatly enhances stability.
Another option is to look for Malm-like furniture made with MDF or solid wood components, which are more suitable for higher loads. Do you plan to use the piece mainly for heavy clothing, books, or perhaps as a TV stand? The intended use can significantly affect the requirements.
I would also be interested to know exactly what you find lacking in the load capacity or in which use case you think the standard version is insufficient?
Leon53 schrieb:
ob es von Ikea Malm Möbeln Varianten gibt, die eine höhere Belastbarkeit aufweisen als die üblichen
I want to approach the topic in a structured way and explain in three steps how to improve the load capacity of Malm furniture yourself if you cannot find specially reinforced versions from the manufacturer.
1. Understanding the materials and construction:
Malm furniture is mainly made of particleboard and MDF – this offers a good balance of weight and cost but has limited load-bearing capacity. The back panel is often thin and serves mainly as a closure.
2. Reinforcing critical points:
- Replace the back panel with a thicker HDF or plywood board, and use screws instead of just nails.
- Add support beams under shelves, for example, attach metal angle brackets.
- Drawers can be reinforced inside with metal runners and sturdy bottoms.
3. Assembly and maintenance:
- Screw everything together carefully and use dowels; tighten any loose parts immediately.
- Avoid overloading individual shelves with excessively heavy items.
Finally, my tip: also check other IKEA furniture series that use solid wood or more robust construction if you need to support heavy loads.
I hope this helps! If you like, please mention the exact load or type of furniture, and I can provide more specific recommendations.
Johnathon schrieb:
I would also be interested to know exactly what you find lacking in the load capacity or in which use case you think the standard version is not sufficient?Thank you for the detailed response, Johnathon. My specific plan is to use a Malm dresser as a base for a somewhat larger monitor plus accessories. In addition, there will be some heavy binders and a few devices that are not really designed for light loads.
[quote[KESIRI, post: w3z0q1, member: XXX]Ikea does not offer Malm models with officially higher load capacities.[/quote]
That helps, thank you.
SUDAN schrieb:
Reinforcement of critical areasThese tips are very helpful. I was initially considering completely replacing the back panel and additionally supporting the shelves. Metal brackets under the shelves might also be a useful idea.
I would be interested to know if anyone is aware of official Ikea products that go well with Malm, such as sturdy shelving systems or compatible shelf inserts.
Background: I want to keep everything as consistent as possible, so replacing the piece with another series is rather not an option.
