ᐅ Are there any known manufacturing defects in the current BILLY models?
Created on: 24 Jan 2021 09:23
tatefa
tatefa
24 Jan 2021 09:23
I have a question that’s been on my mind lately: Are there any known manufacturing defects with the current BILLY bookcases from IKEA? I’m referring to the models available now (early 2021) – especially regarding stability, the accuracy of drilled holes, and the finish quality.
You often find older complaints, but I’m interested in whether there are any current issues or recalls, or if newer production batches are assessed differently in terms of quality.
Maybe there are experiences with quality differences between various manufacturing plants? I’ve heard that some BILLY bookcases have somewhat tight screw holes.
Looking forward to your insights or any specific reports of defects! Thanks in advance!
nojaus
24 Jan 2021 11:07
Hello tatefa,
I can relate to your question, as I recently bought a new BILLY myself and was also unsure whether everything would fit or if there might be any defects.
From my own experience, the drill holes on my shelf were quite precise, but there were some minor scratches on the back panel. Not serious, but annoying.
Even more important, many people here in the forum report that stability can be an issue with tall or heavily loaded units, especially if the shelves are not secured to the wall.
tatefa schrieb:
"especially regarding stability, the accuracy of the drill holes, and the surface finish"
I would say that with the current models there are occasional minor manufacturing defects, but no systematic production flaws. It seems to vary more by batch or due to transport.
Have you noticed any specific problems with your shelf, or are you just looking for general information? I’m happy to help!
Lilygla
24 Jan 2021 13:39
I would like to provide a more detailed response regarding the technical aspects, as I have extensive experience in furniture manufacturing.
Concerning the current BILLY models, adjustments have been made to the production processes in recent years, mainly aimed at more cost-efficient manufacturing. This sometimes results in slight variations in the density of the particleboard material used, which affects durability.
tatefa schrieb:
"especially regarding stability, accuracy of the drilled holes"
Regarding the accuracy of the holes: in the newer series, the drilling is generally very precise since it is computer-controlled. However, there are reports that screws can sometimes be difficult to insert because the wood fibers are quite firm, especially at colder temperatures. This should be handled carefully to avoid any cracking.
The surfaces are coated with melamine resin, which provides long-lasting protection, but the coating on the edges can still be vulnerable. It is worthwhile to inspect all parts for any irregularities before assembly and to request exchanges directly in-store or online if defects are found.
I also wonder if anyone here has experience with reinforcing the furniture using additional fittings? This could be relevant for improving durability.
JAMESONB41
24 Jan 2021 15:02
Briefly regarding the question: I am not aware of any known manufacturing defects in current BILLY shelves. With individual items, there can sometimes be quality variations. Just carefully inspect the product when purchasing and report any defects if found.
Ethan
25 Jan 2021 08:17
I would like to add a point that is often overlooked. The baseboard of the BILLY bookshelf can easily wobble or warp if not assembled correctly. This is not necessarily due to a manufacturing defect, but rather due to the nature of the material and the assembly instructions.
A tip: To increase stability, make sure all screws are properly tightened and take the included corner brackets for wall fastening seriously.
Even though many of you haven’t had any issues, these points are important to ensure the shelves remain secure over time.
Regarding fitting pieces: if an element doesn’t fit properly, sometimes lightly sanding or carefully re-drilling the screw holes (with the appropriate tool) can help.
If anyone has questions about assembly or specific problems, I’m happy to assist.
