ᐅ Are there any known defects or issues with IKEA HEMNES furniture?
Created on: 14 Mar 2018 08:23
besartkaHello everyone,
I am considering purchasing the IKEA Hemnes range, especially bedroom furniture like wardrobes and dressers. Before placing an order, I would like to know if there are any common defects or weaknesses with this model or series based on your experience or known reports that I should be aware of. I am particularly interested in:
- Are there recurring quality issues, such as with workmanship or material quality?
- Are the furniture pieces durable, or are there frequent complaints?
- How is the stability and load-bearing capacity?
- Are there reports of problems during assembly or missing parts?
Thank you for your well-informed opinions and experiences – including any tips on how to avoid potential weaknesses!
besartka schrieb:
I’m thinking about getting the IKEA HEMNES range, especially bedroom furniture like wardrobes and dressers. Before I order, I’d like to know if there are any known issues or weak points with this model or series based on your experience or reports that I should watch out for. I’m particularly interested in:
- Are there recurring quality problems, for example with workmanship or material quality?
- Are the pieces durable, or are complaints common?
- Are there reports of assembly problems or missing parts?Hey besartka! The HEMNES series is quite popular and looks great, but when it comes to drawbacks, here are some occasional issues people mention:
- The surfaces are coated MDF, and the edges can be somewhat delicate, so be careful with sharp objects.
- Some users have reported difficulties during assembly, mainly because some screw holes don’t fit perfectly—sometimes a bit of filing or adjustment is needed.
- The load capacity is fine for normal use, but overloaded wardrobes or dressers can sometimes become unstable.
Overall, I’d say there are no major flaws, just minor quirks that you can handle with a bit of patience and care. 😉
NICOLELIS14 Mar 2018 12:05besartka schrieb:
Are there recurring quality issues, for example with workmanship or material quality?The workmanship is generally good, but the material quality is only average. The furniture holds up well under normal use, but problems may occur if overloaded.
I bought a HEMNES dresser a year ago and can confirm that it is quite sturdy. The only issue was that the drawers were a bit stiff at first, but that improved after using them a few times.
That’s true, I can already see some minor signs of wear on the corners. So, it’s best not to place the furniture in high-traffic areas with frequent contact.
Overall, I’m satisfied, but you shouldn’t expect high-end furniture – it’s a good value for the price.
chen67 schrieb:
the edges can be sensitive in some places, so be careful with sharp objects.
A few months ago, I got the HEMNES bedroom set and I’m really impressed! 😊
Of course, there are minor issues, but for the price, the quality is excellent. Assembly was a bit tricky, but with patience, it works out.
I can only encourage you: If you like solid wood and a certain country style, you will really enjoy it!
A little tip from me: Definitely use the detailed instruction manual and check before assembly if all parts are really included!
To complement the previous posts, here are some objective facts about the IKEA HEMNES series:
- Material: Mainly solid pine wood, partly with MDF panels.
- Manufacturing: Standardized production with a certain level of quality control; however, occasional variations may occur depending on the batch, especially concerning drill holes and fit accuracy.
- Durability: Well suited for use in home environments; signs of wear appear more quickly under commercial or very intensive use.
- Assembly: Instructions are generally clear; any reported fitting issues should be addressed with IKEA on a case-by-case basis.
A frequently discussed weakness is that the surface can be more susceptible to damage from moisture compared to more expensive solid wood furniture. Therefore, proper care and avoiding exposure to moisture are recommended.
