ᐅ Are there furniture waxes that don’t leave streaks on Kallax shelves?
Created on: 8 Jan 2018 09:12
LOURENSFARL
LOURENSFAR8 Jan 2018 09:12Hello everyone,
I have a question that has been on my mind lately: Are there any furniture waxes specifically suitable for treating IKEA Kallax shelves without leaving streaks or uneven spots on the surface?
I have already tried several waxes, but with both unfinished and lacquered Kallax units, I keep encountering the problem that the wax either dries with streaks or appears too glossy in some areas while remaining rather matte in others. My goal is to protect and enhance the wood look without making the surface appear uneven or blotchy.
Does anyone have experience with particular brands or products that work well on Kallax? Are there any special application techniques that help prevent streaking?
Thanks in advance for your expert advice!
Regarding furniture wax on Kallax: Since Kallax is typically made of compressed wood fiberboard with a thin veneer or melamine coating, the surface often reacts sensitively to overly thick wax layers.
Hardwax oils are recommended as they create an even layer and penetrate well into the surface. Products like Osmo Top Oil or similar hardwax oils provide a matte to satin finish with a uniform appearance and no streaks when applied carefully.
In general, I advise always testing on an inconspicuous area first and applying the wax thinly with a lint-free cloth, then buffing well after a short waiting time. This prevents uneven gloss effects.
To answer the question precisely: streaking when applying furniture wax on Kallax usually results from a combination of applying too much product, unsuitable wax composition, and suboptimal application technique.
Products with a hard wax-oil blend (e.g., Osmo, Livos) are better suited, as they spread more evenly and form fewer uneven layers.
I also recommend lightly sanding the surface with fine sandpaper (P240) before application to improve adhesion.
Apply a thin layer, let it sit for 10-15 minutes, then remove excess wax with a clean, soft cloth.
This method largely prevents streaking.
