ᐅ Are there any tips for cleaning IKEA HEMNES furniture when you have pets?
Created on: 11 Sep 2023 19:37
LewimHello everyone,
I am looking for proven tips and methods for cleaning IKEA Hemnes furniture, especially when dealing with pets like cats or dogs. The surface of the Hemnes series is usually painted wood, which can be sensitive to moisture and harsh cleaning agents. At the same time, my pets often leave hair, scratches, and sometimes claw marks or small stains from dirt on the floor in front of the furniture.
Does anyone have recommendations on how to clean and maintain the furniture so that it lasts longer and minimizes the typical wear caused by pets? Are there any special furniture care products, particular cleaning techniques, or practical household tips that have proven effective?
Thanks in advance for all the helpful answers!
Here is a short cleaning tutorial specifically for IKEA HEMNES furniture in homes with pets:
- Step 1: Regularly remove dust and pet hair using a soft broom or microfiber cloth before working with moisture.
- Step 2: For stains, use lukewarm water with a few drops of mild dish soap; never use harsh cleaners or ammonia as they can damage the finish.
- Step 3: Lightly dampen a cloth, wipe the surface, and immediately dry it with a dry cotton cloth.
- Step 4: For scratches, furniture wax or a color-matched wood maintenance marker is recommended to conceal minor damage.
Common mistake: Not drying the furniture immediately, which can cause the wood to swell.
Summary: Use gentle cleaning methods, avoid harsh chemicals, and keep the furniture away from direct heat or excessive moisture.
sinhau schrieb:
Typical mistake: not wiping furniture dry immediately, which can cause the wood to swell.That is absolutely true. I would add that with pets, the development of odors under furniture is often underestimated. Regularly ventilating the room and carefully cleaning the furniture surfaces helps prevent unpleasant smells.
You can also try natural cleaners such as a diluted mixture of water and white vinegar, but please test it first on an inconspicuous area, as the HEMNES finish does not always tolerate it well.
Those who care about maintenance should also occasionally treat the furniture with a suitable furniture oil to protect the surface. This also makes it easier to remove dust and pet hair contamination.
In addition to the previous posts, here is a scientifically based recommendation for cleaning painted wood surfaces like those on IKEA HEMNES, which are exposed to pets:
- Avoid solvent-based or abrasive cleaning products, as they can damage the paint layer.
- Use a slightly damp, soft cloth with a neutral (pH-neutral) cleaning agent.
- Dry immediately after cleaning to prevent moisture absorption.
- To remove pet hair, use an electrostatic dust cloth or specialized pet hair removers that collect hair without causing damage.
- For scratches and minor damage, professional furniture polish with repair waxes is recommended to seal the surface.
These methods help ensure the furniture remains durable for a long time and minimize the impact of pets.
