Good morning everyone, I would like to start a discussion on the following question: Are there any known defects in Ikea Brimnes furniture, especially the versions with drawers or doors? I recently purchased several pieces from this series and have heard multiple comments about the quality, particularly concerning long-term durability and potential weak points. I am less interested in general criticism and more curious about whether specific components (e.g., hinges, drawer slides, particleboard) tend to have problems more often, or if there are any official known defects or recall actions. If anyone has practical experience or reliable information, I would appreciate a detailed response. Thank you in advance!
Hello narpo,
Regarding your question about known defects in the Ikea Brimnes series, there are indeed some points to consider. The Brimnes line is attractively priced, but its construction is not certified for heavy-duty, long-term use, which becomes apparent in practice. Some common weaknesses include:
- Door hinges can become loose or fall off with frequent use, especially if the load is unevenly distributed.
- Drawer slides are mostly metal but tend to become sluggish over time if dust or small debris get inside.
- Particleboard tends to swell when exposed to moisture.
A tip: during assembly, make sure all screws are tightened properly and, if necessary, use some thread-locking compound. This noticeably extends the product’s lifespan.
As far as I know, there are no formal recalls in the traditional sense. The issues are more related to possible quality variations between production batches.
I hope this helps you.
LOGEMIN schrieb:
Particle boards tend to swell when exposed to moisture.That's true! I experienced that with my Brimnes cabinet after about a year because I had it stored in the basement, which sometimes gets damp. Unfortunately, you only notice those small damages once they're already there. 😉
Other than that, the drawer mechanism works quite well for me, although the parts are obviously not designed for heavy-duty use. Given the price, you can't expect too much, but for regular use, it's really fine.
Marcellela17 Nov 2023 14:03Apart from the material quality, I recommend retightening the screws after about six months. This improves stability and prevents the typical creaking in Brimnes.
Keatondra18 Nov 2023 09:21It is quite normal for furniture in this price range to occasionally show such weaknesses. For those considering purchasing Brimnes: make sure not to expose the furniture to high humidity and avoid excessive load. Regular maintenance of the drawers (light oiling, cleaning) and checking the screw connections will significantly extend their lifespan.
If damage does occur, the Ikea customer service is usually very accommodating with spare parts or returns, as long as the warranty period is still valid.
