ᐅ Are Ethernet ports still relevant today? Wi-Fi and wireless connections are the future!
Created on: 29 Jan 2020 21:06
Bauherr am L
Hello fellow cable enthusiasts and Wi-Fi addicts,
I already confessed in the SAT discussion that I consider coax outlets and satellite dishes completely outdated since entertainment is streamed nowadays, and I’m not planning to include them in our new build (more on that in the SAT discussion). But that’s not what this is about.
Right now, I’m trying to smartly distribute LAN duplex Cat 6a and Cat7 cable outlets throughout the rooms (1st floor: 2 kids’ rooms, kids’ bathroom, master bedroom, dressing room, master bathroom, hallway; 2nd floor: open living/dining/kitchen area, hallway, entrance area, guest restroom).
On one hand, I feel like none of the rooms really fit the outlets perfectly, like: “the desk could go here…” But what if the TV ends up in that corner instead?
On the other hand, I’m looking at our current devices and very few still have LAN ports: MacBooks, iPhones, tablets, or devices that have LAN options but mostly connect via Wi-Fi anyway, like Sonos, printers, TVs.
So the question arises whether LAN ports in rooms are still that important today. I’m not talking about the Wi-Fi access points, which of course should be connected via LAN in a convenient location, or special cases like PoE cameras and door intercoms. I’m mainly referring to the LAN outlets in individual rooms. Most end devices are mobile anyway, and the outlets will be in the wrong place 99% of the time.
I read (yes, I spent some time researching this) that the cost of LAN outlets is negligible. Well, if I install duplex outlets in all those questionable locations, the cost for switches and everything else adds up to a nice chunk.
I would be interested in your opinion on this. Since I am straightforwardly skipping any traditional TV (in our case only satellite would be possible) and the corresponding connections, wouldn’t it be consistent to also counteract the outlet overload regarding LAN?
Looking forward to your comments, thanks!
Tolentino7 Jan 2021 11:37
I thought the issue with drywall construction was the metal stud framing, which acts like a Faraday cage. I didn’t consider that trapped moisture could also cause problems...
Mycraft7 Jan 2021 11:39
Wi-Fi is often seen as the solution to everything, but when you look into it more deeply, you realize there are quite a few challenges. However, it is all manageable. Simply use multiple access points 🙂 which is definitely not a bad approach if it solves the problem.
SteffenBank
7 Jan 2021 11:42
More access points are only feasible if network outlets are installed everywhere 🙂 But many rooms have at least a double outlet, so nothing stands in the way of installing an access point in every room. I won’t even start talking about the radiation.
Tarnari7 Jan 2021 11:58
Large potted plants, mirrors, and refrigerators are often challenging as well.
rick20187 Jan 2021 12:04
@SteffenBank as long as you have DECT phones, you don’t need to worry about Wi-Fi radiation.
With multiple access points, you can reduce the transmission power since you have uniform coverage. This is not the case with only a few access points 😉
Most access points should be installed on the ceiling. Plan for this right from the start during new construction.
SteffenBank
7 Jan 2021 12:17
Well :-) The more access points, the more radiation. Just because you use something that already emits a lot doesn’t mean you have to add even more. But that’s another topic.
Yes, it’s best to plan it during the house construction. Most people who worry about Wi-Fi are the ones who don’t have plenty of network outlets installed.
For example, I didn’t have network sockets installed in every room because the prices were just too high. Sure, I could have done it myself, but the network cables were only brought into the house after the plastering was done, so that was no longer an option. However, I have one outlet on the upper floor and ran cables myself from there to the PCs. With our mesh system, that works well for us.
