ᐅ Are Ethernet ports still relevant today? Wi-Fi and wireless connections are the future!
Created on: 29 Jan 2020 21:06
Bauherr am L
Hello fellow cable enthusiasts and Wi-Fi addicts,
I already confessed in the SAT discussion that I consider coax outlets and satellite dishes completely outdated since entertainment is streamed nowadays, and I’m not planning to include them in our new build (more on that in the SAT discussion). But that’s not what this is about.
Right now, I’m trying to smartly distribute LAN duplex Cat 6a and Cat7 cable outlets throughout the rooms (1st floor: 2 kids’ rooms, kids’ bathroom, master bedroom, dressing room, master bathroom, hallway; 2nd floor: open living/dining/kitchen area, hallway, entrance area, guest restroom).
On one hand, I feel like none of the rooms really fit the outlets perfectly, like: “the desk could go here…” But what if the TV ends up in that corner instead?
On the other hand, I’m looking at our current devices and very few still have LAN ports: MacBooks, iPhones, tablets, or devices that have LAN options but mostly connect via Wi-Fi anyway, like Sonos, printers, TVs.
So the question arises whether LAN ports in rooms are still that important today. I’m not talking about the Wi-Fi access points, which of course should be connected via LAN in a convenient location, or special cases like PoE cameras and door intercoms. I’m mainly referring to the LAN outlets in individual rooms. Most end devices are mobile anyway, and the outlets will be in the wrong place 99% of the time.
I read (yes, I spent some time researching this) that the cost of LAN outlets is negligible. Well, if I install duplex outlets in all those questionable locations, the cost for switches and everything else adds up to a nice chunk.
I would be interested in your opinion on this. Since I am straightforwardly skipping any traditional TV (in our case only satellite would be possible) and the corresponding connections, wouldn’t it be consistent to also counteract the outlet overload regarding LAN?
Looking forward to your comments, thanks!
knalltüte
7 Dec 2020 20:11
I have a used Hilti DX450 (with bolts and plenty of ammunition) available, but so far I’ve been too hesitant to try it myself. I’ve never even held a firearm before... 😉
Stefan2.84
7 Dec 2020 20:13
I checked again. It’s a Bosch rotary hammer. Probably the wrong drill bits. I’ve now ordered the ones mentioned above. It should work then… hopefully.
K1300S7 Dec 2020 20:47
If it is a rotary hammer, make sure to use the SDS-Plus chuck with the appropriate drill bit, as @Mycraft has already recommended, and if it is interchangeable; otherwise, you won’t benefit from the hammer function.
Stefan2.84
12 Dec 2020 08:46
Quick update: Tested a rotary hammer with an SDS Plus chuck and matching drill bits, and found it to be perfect. It really goes through without any problems....
O
Olli-Ka
12 Dec 2020 09:04
the comparison between a toothpick and a hot knife couldn’t be more accurate.
Olli
Stefan2.84
12 Dec 2020 13:08
That’s roughly how you could put it. In any case, it works really well.
opalau schrieb:
In the end, I ordered 18cm (7 inches) wooden panels that are 6mm (0.24 inches) thick, glued three of them together, sanded, painted white, and then hollowed out in the middle using a hole saw. Then, together with the Unifi adapter plate, I mounted it on the ceiling.
So you screwed your adapter plate to the ceiling and then attached the AC mount to that?
