Meoruzgar9 Mar 2019 18:07Hello everyone,
I recently bought an IKEA Malm chest of drawers with multiple drawers and have noticed that some of the drawers are slightly misaligned or do not close properly. I have already tightened the screws and checked the drawer slides, but the drawers still don’t seem to be perfectly aligned.
My question is: how do you correctly align the drawers of the IKEA Malm chest so that they glide smoothly, run parallel, and close cleanly? Are there specific adjustments on the drawer runners or on the sides of the drawers that I need to make?
Ideally, I would need a step-by-step guide, as I want to know exactly what to pay attention to (for example, which screws to loosen, how to precisely position the drawer, and how to check the parallel alignment).
Thank you in advance for your tips!
Hello Meoruzgar,
I read your question and would like to give you a brief guide on how to properly align the IKEA Malm drawers so they run smoothly and close cleanly.
1. Fully extend the drawer: Pull the drawer all the way out so you can easily access the slides.
2. Check the slides: Make sure the slides on both the drawer and the cabinet are firmly and evenly installed. Tighten any loose screws.
3. Adjust the slides: IKEA Malm uses simple ball-bearing slides without advanced micro-adjustments, but you can slightly shift the drawer sides. Loosen the screws on the outer slides attached to the drawer frame just a little.
4. Align parallel: Now, push the drawer back in a bit and gently tilt or adjust it. Make sure the drawer runs parallel on both sides within the slides.
5. Secure: Once the drawer sits correctly (no binding, even gaps), retighten the screws.
6. Minor unevenness: Sometimes, placing a thin piece of paper or felt at the cabinet edge helps if the front sticks slightly (don’t overdo it).
Summary: There is no sophisticated adjustment mechanism; the key is to check the slides and screws, use the small tolerances, and align the drawer as you push it in. Pay attention to smooth guidance and a tight fit.
Good luck! If you have more questions or need further details, feel free to ask.
Hey Meoruzgar,
first of all: hats off to you for tackling this so thoroughly! 🙂 Aligning the Malm drawers can sometimes be a bit fiddly, but once you get the hang of it, it runs smoothly.
What I’d like to add: you can sometimes slightly adjust the drawer front by loosening the small screws on the back of the front panel and shifting it gently. This is a real gamechanger when the gap between the drawer front and the side of the dresser isn’t quite right.
That sums it up well.
My tip: take it step by step, don’t do too much at once, or you can easily lose track. And always push gently—using too much force can cause new issues.
Good luck and don’t get discouraged :-)
tolokau schrieb:
There’s no sophisticated adjustment mechanism; the trick is to check the rails and screws, use small allowances, and align the drawer as you slide it in.
Genevieve11 Mar 2019 08:36Hello everyone,
I would like to ask a somewhat critical question: Malm drawers are often considered simple, and you mostly hear about minor screw adjustments. But are there actually documented tolerances from IKEA regarding how precisely the drawers need to fit within the frame? Or are the alignment tips mostly based on subjective experience?
This question is interesting because IKEA typically relies on mass production, and not all components can be perfectly precise. This inevitably leads to consumers having to do some fine-tuning.
I would say the problem stems from the limited adjustability of the hardware. It would be interesting to know if there are alternative drawer slides that offer better adjustability and could serve as replacements for the Malm model.
The discussion could benefit from anyone sharing technical details about the mechanical components or tool use that enable a lasting solution. Simply tightening screws is not always enough.
What do you think?
Meoruzgar schrieb:
Are there specific adjustments I need to make on the drawer slides or on the sides of the drawers?
tolokau schrieb:
There is no sophisticated adjustment mechanism; the trick is to check the rails and screws, use small tolerances, and align the drawer while sliding it in.
What do you think?
