ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Z
Zaba12
8 May 2021 11:55
Bookstar schrieb:
You seem to have quite a lot of sun, but why you don’t need heating remains a mystery given the temperatures. At night we still have temperatures well below 10°C (50°F), and right now it’s 12°C (54°F) outside. Of course, the heat pump will eventually kick in...
The last few days without sun have been borderline in terms of indoor temperatures. We’re glad the sun is shining today and the blinds are raised, so all surfaces can warm up again. We didn’t even have such low indoor temperatures when we only heated with a fireplace until December. Just for the sake of completeness, our house has its limits too.
Daniel-Sp
8 May 2021 12:13
Then you need to raise the base point of the heating curve.
Z
Zaba12
8 May 2021 12:26
Daniel-Sp schrieb:
Then you have to raise the base point of the heating curve.
Understood 😎. But that only works if the heating was on, which has been off for almost 3 weeks now :p
4
4lpha0ne
8 May 2021 13:21
Zaba12 schrieb:
Sure, no problem 😎. But that only works if the heating is on, which has been off for almost 3 weeks now :p
Is it controlled by a century-old weather calendar or just inactive due to settings or the heating being turned off, so that even the flow temperature doesn’t make a difference here? 😉
Z
Zaba12
8 May 2021 13:36
Manually turned off the heating system.
Daniel-Sp
8 May 2021 14:42
Then there’s no reason to complain...
