ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Daniel-Sp
29 Dec 2020 15:31
tomtom79 schrieb:
Also, the return temperature should not rise too quickly during the first 15 minutes.
In well-balanced systems, the return temperature should only start to increase after 8-10 minutes.
Daniel-Sp
29 Dec 2020 15:33
Zaba12 schrieb:
That doesn’t happen, quite the opposite.
Didn’t you have an issue with the return sensor?
Z
Zaba12
29 Dec 2020 15:35
The offset has stabilized and varies by a maximum of 0.3 degrees.
Daniel-Sp
29 Dec 2020 15:41
Zaba12 schrieb:
The offset has stabilized and fluctuates by a maximum of 0.3 degrees Celsius (0.5 degrees Fahrenheit)
What did you do?
Z
Zaba12
29 Dec 2020 17:16
Nothing. Let it run through and don't adjust anything further.
HarvSpec
29 Dec 2020 17:20
We currently use 20 kWh/day for our Viessmann heat pump. It is a major renovation of a 170 m² (1,830 sq ft) living area.
