ᐅ After installing sound boxes, the entire KALLAX unit vibrates – how can this be prevented?
Created on: 11 Nov 2024 14:07
Scheref
Scheref
11 Nov 2024 14:07
I mounted new speakers on my IKEA KALLAX shelf, but now the entire shelf vibrates noticeably when the bass is strong. The speakers are a bit heavier and stand directly on the top shelf surface – this causes the shelf to resonate, especially when the bass hits hard.
My question is: What options are there to reduce or completely eliminate this vibration without changing the placement of the speakers? Can certain dampers, pads, or other measures suppress the KALLAX’s resonance?
It is also important to me that the shelf remains stable and its appearance is not significantly altered. Thanks for your tips!
nolan
11 Nov 2024 14:23
Hi,
try placing damping rubber pads or anti-slip mats under the speakers. This isolates the vibrations and reduces their transmission to the shelf.
blapau
11 Nov 2024 15:04
That is definitely a sensible first step. Additionally, I would check whether the gaps and joints of the KALLAX are already firmly secured. Vibrations often increase due to small gaps or loose screws. Tightening and stabilizing can help minimize resonance.
Domau0
11 Nov 2024 15:52
to address your problem effectively and sustainably, it is important to analyze the structure carefully.
1. Material and construction method: The KALLAX is a carcass shelf made of particleboard, originally not designed for heavy or vibration-intensive loads like speakers with strong bass. The side panels and shelves are relatively thin and can easily start to vibrate.
2. Vibration mechanics: When bass waves hit the speakers, they generate acoustic vibrations that transfer to the shelf surface. An unstable base or loose connections amplify this effect.
3. Measures:
- Damping materials (foam, rubber mats) placed between the speakers and the shelf can reduce mechanical transmission.
- Anti-vibration feet or at least sturdy rubber pads provide better decoupling.
- The shelf itself should definitely be fixed to the wall or floor, depending on what is possible.
- If the KALLAX shelves are large, internal reinforcement with an additional board or brackets may improve stability.
Could you specify in more detail how the speakers are placed on the shelf (directly, on stands, orientation)? Also, how thick is the shelf board, and have you already fixed the shelf in place?
Scheref
11 Nov 2024 16:08
Domau0 schrieb:
Could you be more specific about how the speakers are placed on the shelf (directly on the surface, on stands, orientation)?
The speakers are placed directly on the shelf surface, with no additional stands. The shelf surface is about 1.5 cm (0.6 inches) thick, and the shelf is not fixed to the wall; it stands freely. The shelf is mainly used as a hybrid stereo system and is currently positioned roughly in the center of the room.
blapau schrieb:
often vibrations are amplified by small gaps or loose screws
I will check that and tighten any screws if needed, thanks for the tip.
ju_ren
11 Nov 2024 18:29
Attach the shelf to the wall, as this significantly reduces resonance. Additionally, rubber pads under the speakers help as well.
