ᐅ After every move, my KALLAX becomes less stable – is there a way to reinforce it?
Created on: 10 Jun 2016 14:27
EmirjonHello everyone,
I have a specific question about my issue with the KALLAX shelf and am hoping for your experiences and tips. After every move, I notice that my KALLAX shelf becomes a bit less stable than before. It seems that the joints and overall structure start to lose stability due to frequent disassembly and reassembly. In particular, the back panel and corner connections no longer feel as secure as they did initially.
My specific question: Are there any proven methods or additional reinforcements to make the KALLAX shelf safer and more stable after each transport or rebuild? I am thinking of techniques or materials that can be applied relatively easily without significantly altering or damaging the furniture. Are there reinforcement options that can be targeted specifically at the weak points?
I look forward to your feedback and hope someone has practical experience with stability-enhancing solutions. Thank you in advance for your support!
Emirjon schrieb:
My specific question: Are there proven methods or additional reinforcements that I can use to make the KALLAX shelf more secure and stable again after each move or reassembly?Hello Emirjon,
First of all, I find your description very precise – that helps a lot in finding a solution. The instability of your KALLAX after several moves is not an unusual problem. IKEA furniture is designed for easy assembly, but not always for frequent disassembly and reassembly.
There are several reinforcement approaches I can recommend:
1. Secure the back panel: If the existing back panels are thin or coming loose, you can reinforce them with additional small nails or even a suitable thin plywood board. This increases lateral stability.
2. Strengthen corner joints: Many KALLAX models use dowels and screws. To achieve more stability here, you can apply wood glue to the joints before screwing them together. Important: let the glue dry thoroughly! Alternatively, there are flat metal brackets that can be attached invisibly from the back.
3. Fix the top and bottom panels: If the upper and lower panels wobble slightly, these areas become weak points. Thin metal brackets can be attached inside at the bottom to prevent rocking.
4. Rubber pads & adjustable feet: To compensate for uneven floors causing wobbling, adjustable feet or small rubber pads are useful. These also minimize stress when moving.
My tip: Take enough time during the next assembly and check the fit of the dowels and screws carefully. If they don’t fit exactly, this leads to instability.
If you want, I can also share some practical guides or sources for reinforcement materials.
Good luck and feel free to reach out with any further questions!
alvalo schrieb:
There are flat metal brackets that can be attached invisibly from the back.That’s really a great tip, alvalo! 🙂
I had a similar problem with my KALLAX because I kept moving it around. My secret tip: wood glue combined with small brackets like those really makes a difference. Just glue and screw them onto the corners—and suddenly the shelf stands rock solid.
Also, I always made sure to firmly staple the back panel (instead of just gluing it), which really helps a lot. When I’m in a hurry and the shelf is a bit wobbly, I also like to use small anti-slip pads under the feet—they help reduce vibrations during transport.
Emirjon, if you want, you could also try swapping the back panels for sturdier boards. I got some thin plywood sheets cut at the hardware store, which are more stable than the original cardboard. Saved me a lot of hassle after my third move. 😉 Have fun with your project!
Emirjon schrieb:
I’m thinking of techniques or materials that can be applied relatively easily without significantly altering or damaging the piece of furniture.Interesting approach, but I would consider this a bit more broadly: In my opinion, the stability of a KALLAX shelf depends not only on the connectors but also significantly on the structural load and the handling during assembly and disassembly.
Is it possible to avoid fully dismantling the shelf as often? Minimal modifications combined with permanent nailing or screwing in between could make the structure last much longer. The risk with repeated disassembly is that the components could become weakened or the connector holes could widen.
Another idea—though it would require drilling—is to reinforce the interior with metal profiles that are glued or screwed from the inside instead of just using brackets. Some people also use so-called “wood connectors” or angle brackets that remain nearly invisible but provide tremendous support.
One aspect that should not be overlooked is the load on the shelf. Heavy books or equipment increase the risk of wobbling. I recommend considering the loads and distributing them as evenly as possible.
Conclusion: If the goal is maximum durability despite frequent assembly and disassembly, some modifications will likely be necessary. Simply adding brackets can help but may not always be sufficient.
Perhaps neo59 can share more about how the shelf is used?
