ᐅ Additional Costs for Adding a Shower to the Ground Floor (Guest Bathroom)
Created on: 14 May 2015 09:34
O
onkelchen2k
O
onkelchen2k
14 May 2015 09:34
Has anyone had experience with the additional costs to expect for installing a shower in a guest bathroom within a turnkey home build?
Assumptions:
  • Additional costs for design changes to the floor plan are not considered; starting size of the guest bathroom: 3 sq meters (32 sq ft)
  • Basic standard fixtures (No walk-in shower, mid-range fittings)
  • No additional heated towel rail (Only the existing underfloor heating; the shower is intended for quick use: quick in, quick dry, quick out)
Thank you for your feedback.
Häusle77
14 May 2015 10:28
We were quoted an additional cost of 1200€.
However, this means giving up one square meter in the utility room...
Dindin
14 May 2015 10:56
We paid a similar additional cost as Häusle77 for the floor-level shower in the ground floor guest bathroom. I believe this definitely varies depending on the provider.
Payday
9 Jun 2015 21:45
The approximate amount of 1200 euros was also offered to us by 3 builders. That is about right.
9 Jun 2015 22:03
One should keep in mind:
if the building supervisor/site manager or the building authority requires 3000, then you cannot change that just because others only want 1200 😉
At least you have a reference value.
