ᐅ Does an external chimney need to extend all the way down to the basement?
Created on: 25 May 2015 19:29
AbbygaleHello everyone,
I have a quick but very important question for us:
We want a tiled stove on the exterior wall of the ground floor (building on a slope). The architect plans to extend the external stainless steel chimney all the way down to the basement or lower ground level. However, this limits us a lot – an entire balcony door would have to be removed because of this.
My question is: Is it necessary for the chimney to go all the way down, or can it start directly at the fireplace on the ground floor?
Thank you very much for your answers. I would like to have the right arguments ready when I speak with the architect tomorrow.
Sebastian7925 May 2015 21:39You need to clarify this with the local chimney sweep—not with the architect.
For solid fuels, a damper is usually installed both at the fireplace and at the top of the chimney—although this might be different for stainless steel flue pipes.
By doing this, we avoided installing a chimney draught into the basement, saving about 400 euros.
Bauexperte27 May 2015 12:15Hello Olli
Regards, Bauexperte
wrobel schrieb:Could you please explain why?
If possible, I would try not to have the chimney made of stainless steel and not placed outside the building, for technical and aesthetic reasons.
Regards, Bauexperte
Sebastian7927 May 2015 12:52At least visually, I can understand it – there is (subjectively) hardly anything more unattractive for a new build than this silver stove pipe.
