ᐅ Floor plan: Staircase design - steps in the turn
Created on: 21 Jan 2025 10:26
Contact2001
I have a floor plan here where the staircase has been designed with only two steps in the lower turn but three steps at the top. Does that make sense?
The floor-to-floor height is 3.15 m (10.3 ft) with 17 steps; the rest you can see in the drawings.
Would you build it like this, or would you do something differently under certain circumstances?
Thank you very much,
Mike
Grundriss eines Hauses mit Wohnzimmer, Küche, Eingang, Garage (Autos), Garten.
11ant22 Jan 2025 16:48
Contact2001 schrieb:
This is a stepped area: the lower half has a standard floor height, while the upper half is about 1–1.3 meters high (approximately 3.3–4.3 feet), essentially a platform. This is not visible in the drawing. The headroom is sufficient.
I would be lying if I said I have a clear understanding of the situation now.
22 Jan 2025 18:51
This is a stepped area; the lower half has a normal floor height, the upper half is about 1–1.3 m (3.3–4.3 ft) high.
Only two steps at the turn down below.
The larger double steps.
Two steps contradict each other...
Basically a landing.
... with a landing.
Contact2001
23 Jan 2025 10:07
I would be lying if I said I have a clear understanding of the situation right now.
This is a very rough sketch (not to scale and taken from another thread, sorry), and it might not even help, but the staircase was designed this way to ensure head clearance.
The lower edges of the "stair overhang = floor and landing in the upper floor room" are also chamfered to provide additional headroom.
If we reduce the upper turn to only two steps instead of three, then the floor and the "landing" on the upper floor above the staircase need to be raised by about 18.5 cm (7.3 inches) for head clearance, which means we lose some storage space. The advisor thinks having only two steps in the turn is better because it offers a larger tread area. My question is: how much safety improvement does this actually bring, and does having only two steps at the top significantly disrupt the natural walking pattern?
Sorry for all the questions—I hope this is somewhat clear.
Technical drawing of a staircase in section A-A with railing and dimensions
11ant23 Jan 2025 13:05
This is a very poor graphic (not to scale and taken from another thread, sorry) and it might not even be helpful, but the staircase was designed this way to ensure head clearance. [...]
Sorry for all the questions, I hope it’s somewhat understandable.
It’s better to take it directly from your architect’s plans; that might help and could even make it understandable.
kbt09
23 Jan 2025 13:07
I also think that both options should be presented as proper cross-sections with height dimensions, similar to the head clearance pattern I created in your last post.
hanghaus2023
23 Jan 2025 14:35
You have a ceiling height of 3.15 m (10.3 feet), but the sketch shows 2.95 m (9.7 feet). So you can cover one more step. I have 2.04 m (6.7 feet) and have no problem (I am 1.80 m (5.9 feet) tall). However, it’s not very comfortable. If you are 2 m (6.6 feet) tall, you can’t avoid ducking your head.
