we would like to share our design with you to get feedback and suggestions for improvements, as well as to identify any potential issues.
With the optimized design, we plan to approach construction companies for quotes. All the architects we contacted have long waiting times, and since we need to apply for funding in spring, that would not be feasible timing-wise.
What do we want to build?
A single-family house with a maximum of 160 m² (approximately 1720 sq ft) according to the living space regulations (with the terrace counted proportionally) in order to qualify for funding.
Plot size: 645 m² (approximately 0.16 acres)
Slope: yes, slight. The plot is about 28 m (92 feet) long and rises about 1.5 – 2 m (5 – 6.5 feet) from the street (south) upwards.
Site coverage ratio: 0.4
Floor area ratio: 0.8
Building envelope, building line and boundary: The building boundary is 2.5 m (8 feet) from the front and rear (as viewed from the street). Roof overhangs may project up to 1 m (3 feet) beyond the building boundaries, provided the setback requirements of the state building code BW are met. Garages may be built outside the buildable areas.
Border development: Neighbor’s garage to the west on the boundary, see site plan. Both neighbors east and west have already built. On the opposite street side (south) is still a free building plot. North is a field with no planned development.
Number of parking spaces: 2, preferably a double garage.
Number of floors: 2 possible.
Roof shape: free choice.
Style: free choice.
Orientation: southwest (SW).
Maximum height limits: maximum height of 8.5 m (28 feet) measured from the ground floor level to the highest point of the roof structure (for roofs up to 7°, only 7.5 m / 25 feet height allowed).
Other requirements: ground floor height max. 0.5 m (1.6 feet) above street level; mandatory photovoltaic system (BW), mandatory cistern (~6 m³ (1580 gallons)).
Client requirements
Style, roof shape, building type: classic gable roof house, 30° roof pitch, 1.4 m (4.6 feet) knee wall.
Basement, floors: no basement, 1.5 floors.
Number of occupants, age: 3 persons, ages 32, 28, 0.
Space requirements on ground floor (GF) and upper floor (UF):
GF: living-dining-kitchen approx. 45 m² (484 sq ft), office/guest room approx. 10 m² (108 sq ft), utility/technical room approx. 8-10 m² (86-108 sq ft), shower bathroom approx. 4 m² (43 sq ft).
UF (all net floor area): bedroom approx. 14 m² (151 sq ft), bathroom with laundry room approx. 16 m² (172 sq ft), 2 children’s rooms approx. 16 m² (172 sq ft) each.
Since we currently plan for only one child, the office on the GF should serve as storage and guest room; the second "children’s room" will be used as an office. Approximately 15 guests per year; home office about 3 days per week.
Open or closed architecture: open.
Conservative or modern style: more or less modern.
Open kitchen, kitchen island: yes.
Number of dining seats: normally 4, extendable up to 12.
Fireplace: no.
Music/stereo wall: no.
Balcony, roof terrace: no.
Garage, carport: yes, preferably double garage at least 6 x 7 m (20 x 23 feet).
Utility garden, greenhouse: no.
Additional wishes / special features / daily routine, including reasons for certain choices or exclusions:
Who designed it: Do-it-Yourself.
What do you like most and why?
What do you dislike and why?
Cost estimate by architect/planner: -
Personal budget limit for the house, including fittings: €520,000 (around US $570,000), excluding landscaping, must be reduced by personal labor.
Preferred heating system: not decided yet, no fossil fuels allowed, likely air-to-water heat pump.
If you had to give up something, on which details or expansions could you do without:
What could you not do without:
Why is the design the way it is?
We approached three construction companies, received some good but too large plans, and some standard plans that did not fit at all. Therefore, we studied floor plans intensively and tried to create a design with as few compromises as possible. Because of our wish for a side entrance and the living-dining-kitchen area arranged as an L-shape on the southwest side of the house and the two children’s rooms facing south without dormers or small gables, we couldn’t find 1.5-story designs from prefab house providers that fit.
After considering many other designs, we ultimately drew this one ourselves, which we basically like best and is just acceptable in size. The bay window for the stairs will probably cause extra costs, but we hope to compensate by omitting a flat roof and extending the roof line.
The ground floor ceiling height is an assumption; the stairs are planned for a floor height of 2.83 m (9.3 feet), with 26 cm (10 inches) tread depth and 18 cm (7 inches) riser height.
In addition to comments and suggestions on the floor plan, we also have the following questions:
Thank you very much in advance for your help! I will gladly provide any information available if needed.
Please be kind, this is my first post and
Style: free choice.
Client requirements
Fireplace: no.
- The kitchen should not be visible from the sofa (when sitting).
- The living-dining area with kitchen should be the “heart” of the house.
- The shower bathroom and stairs (and if possible the guest room) should not be accessible through the dirt zone at the entrance door.
- Sufficient cloakroom space.
- Washing machine & dryer in the bathroom on the upper floor, as laundry accumulates there, but separated from the children’s rooms by the hallway.
- Gable or dormer facing southeast (street side) due to the view.
- No dormers or more costly architectural features due to cost reasons.
- Terrace mainly on the southwest side to catch evening sun. It will later be covered with a pergola. A 3 m (10 feet) lift-and-slide door would be ideal.
- Ground floor ceiling height at least 2.5 m (8.2 feet), upper floor 2.4 m (7.9 feet) is acceptable.
- Spacious living-dining-kitchen area with kitchen not visible from the living room.
- Light-flooded living spaces.
- Possibility to later separate the living room with, for example, glass elements.
- Space available for furniture placement in living room.
- Modern feel due to open staircase.
- Staircase accessible from living area (natural access to bathroom or bedroom).
- Visual axis from entrance to garden through window behind the stairs, without having a view of the entrance door from the rooms.
- Implementation of basic wishes (number of rooms, orientation, functionality, etc.).
- Minimal actual hallway area on ground floor.
- No separation from upper floor possible.
- Head clearance to the first landing of the stairs is critical.
- Overhang in front of left children’s room is wasted space.
- No window in the shower bathroom on the ground floor.
- Dirt corridor & relevant rooms are separated.
- If a second child comes, there is little storage space.
- With about 155 m² (1668 sq ft), relatively large (and therefore expensive).
- Exterior appearance, but we have not focused on this as a priority so far.
- Southwest terrace has a possible sliding door that is too small (currently 1.5 m / 5 feet), so this door is planned 3 m (10 feet) slightly to the south instead.
- No pantry; we would consider a small cupboard and fridge-freezer in the technical room if space permits.
- Very long driveway.
- Unfortunately relatively close to neighbor’s plot on the southwest side.
- Large guest/work/storage room.
- Shower on ground floor.
- Laundry room on upper floor.
- Side entrance to the house.
- Generous living-dining-kitchen area.
- Is the size of the living area including the stairs structurally feasible without issues?
- How complicated and expensive would ventilation for the shower bathroom on the ground floor be?
- Is the head clearance for the staircase sufficient?
- Are knee wall windows, as planned in the children’s room, worthwhile? We see advantages in improved lighting for a small seating area and ventilation possibilities via a tilt window.
Lift-and-slide doors are the retro trend of the future, and especially with a total width of 3m (10 feet) they are also an inconvenient size. Why exactly "dream"? Retro or not. It depends on the application. Sliding doors make sense where you don’t have space for a swing door and want a large opening. For opening and closing all the time, they are obviously impractical.
Clear ceiling height of 250cm (98 inches) was standard forty years ago, in the era of hanging ceiling lamps. The hanging lamps are coming back again, just as the loft look with lift-and-slide doors is fading. The fact is also that many development plans require that an additional floor level be allowed first. In our case, with two full floors, we can’t build any taller. The eave height is 6m (20 feet), the ridge height is 9.3m (30.5 feet). Whether the usual increase of 20cm (8 inches) to 2.7m (106 inches) really makes such a huge difference—an increase of a mere 8%—I would also doubt.
wiltshire10 Jan 2025 13:37roteweste schrieb:
Retro or not. It depends on the application. Sliding doors make sense where you don’t have the swing space and want a large opening. For constantly opening and closing, they are obviously not practical. An alternative to a “large opening” with limited space are folding systems. We installed some from Solarlux and placed the folding section on the outside. This way, there is zero space needed inside the room and the opening is significantly larger than with a sliding door.
Our short-haired collie puppy Evi is sleeping with the window open. The frame and four folding panels (pushed to the left in the picture) take up about 50cm (20 inches) of the total window opening (just under 4m (13 feet)).
chand198610 Jan 2025 13:48wiltshire schrieb:
An alternative to a “large opening” with limited space is folding door systems. We installed some from Solarlux and positioned the folding section on the outside. This way, there is zero space needed inside the room and the opening is significantly larger compared to a sliding door.
Our Kurzhaarcolliewelpe Evi sleeps with the window open. The frame and four folding panels (pushed to the left in the picture) take up about 50cm (20 inches) of the total window opening, which is just under 4m (13 feet). May I ask if you don’t have any issues with insects entering, or if they simply don’t bother you? When we open our large sliding door briefly in spring without closing the insect screen, I might as well start a new Krefeld study in the living room.
wiltshire10 Jan 2025 13:52No roller shutters or Venetian blinds – for those, the folding mechanism would need to be installed on the inside (which is also common). The roof overhang is designed so that at the highest sun position during summer, sunlight does not enter through the windows, while in winter, the sun reaches the entire room. The location of the house is such that you would need binoculars from the other side of the valley or viaduct to see inside. So, privacy and sun shading are well managed. We have two of these in our living area, and they remain almost fully open throughout the summer – inside and outside become almost indistinguishable. We are now in the sixth trouble-free year, and the doors operate smoothly. When the terrace wood warped slightly, we had to address that because we do not have a threshold leading outside. However, this was unrelated to the windows.
wiltshire10 Jan 2025 14:05chand1986 schrieb:
May I ask if you don’t have any insect issues or if they just don’t bother you? When we have the large sliding door open briefly in spring without the insect screen pulled across, I can start a new study of insects in the living room. Of course, insects can be annoying sometimes. Mosquitoes tend to go for me; my wife is usually safe.
I don’t try to enjoy all advantages at once. A few clear priorities with decisions aligned accordingly are enough. Having no insects at all is not even on my life’s priority list. Being able to live both indoors and outdoors during summer, on the other hand, is. An insect screen would interfere with that priority, so there isn’t one.
