ᐅ Site Planning for New Single-Family Home Construction, 180 sqm, with Space for a Grand Piano
Created on: 10 Dec 2023 20:59
DerBer1
DerBer1
10 Dec 2023 20:59
I have mostly been a silent reader until now, but I’m stuck with my plans and need some advice. Here are the basic details first:
Plot size 900 sqm (already owned)
Slope Entire plot drops from north to south by about 1.2 m (4 ft) over 29 m (95 ft), within the building envelope of the house over 13 m (43 ft) it drops about 0.6–0.8 m (2–2.5 ft)
Site coverage ratio 0.2
Floor area ratio 0.33
Building envelope, building line, and boundary House 15x11 m (49x36 ft), garage 6x8.5 m (20x28 ft); garage width can increase if it remains within the building envelope of the house.
The building envelope was defined for a smaller plot, which was later extended eastwards (see image Baufenster.jpg). I assume the envelope may be moved east accordingly, but approval is still pending.
Edge development Garage only
Number of parking spaces 2
Number of storeys 2 full floors
Roof type Gable roof with 25–30° pitch
Orientation View from living-dining area towards northwest, as this side is unobstructed
Maximum heights / restrictions
- Wall height 6.1 m (20 ft) (measured from top of ground floor slab)
- Base height 0.3 m (1 ft) (from top of ground floor slab)
- Excavations not allowed
- Filling up to 0.5 m (1.6 ft) allowed
- Width-to-length ratio must not significantly deviate from 1:1.2
- Excavations and fillings allowed for garage access (base height up to 1 m (3.3 ft))
</TD]
Basement, floors
Number of occupants, age Currently 2 adults + 1 child (space for a second child must be possible)
Space requirements on ground floor Large entrance area with lots of storage,
generous living-dining room with pantry,
guest room, guest bathroom
Space requirements on upper floor Bedroom with optional separate walk-in closet, bathroom, child’s bedroom 1, home office. (If there is a basement, the guest room will move there to make space for a second child’s room upstairs. Without a basement, a second child’s room is needed on the upper floor.)
Office Required (1 home office)
Occasional overnight guests per year Occasionally for 1–2 days, about 5–10 people.
Open or closed design Mixed. Staircase outside the living area, but an atrium in the entrance area would be nice. Open living-dining area is good for spaciousness, but it would be advantageous if it can optionally be separated.
Open kitchen, kitchen island Open kitchen yes, kitchen island not required. We prefer a U-shaped kitchen for short distances.
Number of dining seats 6+2 (dining table size 2.2x1 m (7.2x3.3 ft))
Music/sound system wall, TV wall Should be on one wall and provide storage space. We didn’t like a design where the TV acts as a room divider between living and dining.
Balcony, roof terrace If there is space in the bathroom for a sauna, a balcony would be nice. Probably omitted for cost reasons.
Garage, carport For 2 cars. Garage obviously preferred but not essential. Possibly a combination where the carport also covers the main entrance.
Special considerations View towards southeast is not pleasant due to industrial sites.
Homeowner requirements
Bright with lots of space, modern, open but not too stylish. Function follows design.
Lots of space and storage, no dark hallways, entrance area ideally with an atrium.
Guest bathroom and staircase to upper floor should not be directly at the main door (to avoid dirt area).
We have a grand piano (1.6x1.8 m (5.2x6 ft)), which must be accommodated in the house (an heirloom with personality, occasionally played). Ideally in the living room on the ground floor in a dark corner to avoid direct sunlight. Alternatively upstairs, but definitely not in the basement.
Well insulated. We are considering QNG certification to qualify for the KfW loan, but not if it leads to unreasonable extra effort.
Planned by: Do-it-Yourself
What do you especially like?
The version with a straight staircase is basically just a larger version of the sample house with a 10x12 m (33x39 ft) footprint. I’m not a fan of straight stairs, and the basement access would go through the living room. However, the entrance with a separate wardrobe is appealing.
With the bay window variant: the bay window likely increases costs. The guest bathroom is accessed through the dirt zone near the entrance door. If I swap staircase and guest bath, the bathroom won’t have a window unless I move the garage forward as well.
With the 10x12.5 m (33x41 ft) variant: The grand piano somehow doesn’t fit well.
Personal budget limit for house, basement, including fittings, garage, terrace, driveway
900,000
Preferred heating system:
Air-source heat pump with underfloor heating and ideally also central residential ventilation.
If you have to give up on certain features or expansions, which ones would you drop?
The grand piano can be moved upstairs if necessary. The garage can be replaced by a carport.
Which features can you absolutely not do without?
The basement is still under discussion. My wife prefers having a basement. I could live without one.
Why is the design like it is now?
Experimenting with SweetHome 3D after studying many show homes and floor plans, none of which suited us because a room was always missing or there wasn’t enough space for the grand piano in the living area.
The goal is to get a rough idea of how much living area is needed to fit all the desired rooms, so we can then estimate costs.
I try to keep the footprint to 10x12 m (33x39 ft) so that the overall living area doesn’t get out of hand. However, this limits fitting a guest room as well as the grand piano on the ground floor. The space shouldn’t feel cramped. I definitely do not want to make it bigger since we don’t need extra space upstairs.
I’m open to all criticism. My thinking is probably stuck on these floor plans, so a push in a completely different direction might be helpful.
Questions I am asking myself:
  • Is a budget of 900,000 enough to cover house + basement + garage + driveway + terrace and garden fence?
  • Is a basement significantly more expensive? If I need a utility room, storage, and a second child’s bedroom instead of a basement, that’s also quite costly.
  • Does it make sense to put the guest room in the basement? We hope to get some daylight in a southeast-facing basement room, as this is the lowest part of the plot and excavation will be necessary for garage access anyway.
  • Can I fit all my requirements into a 10x12 m (33x39 ft) footprint without the grand piano feeling too cramped?
  • Is a standard house (or free planning with a general contractor) enough for our needs, or should we definitely consult an independent architect beforehand?
  • Is the house orientation reasonable or are there better options? We are quite restricted by the building envelope but other houses in the development deviate considerably. We intend to request moving the house eastwards since the plot has been expanded there.
  • Does it make sense to put the garage basement instead of the house? We don’t need a large basement, but 50 sqm (540 sq ft) would be good.
Aerial photo of residential area with red roofs, roads, and yellow-marked plots.
Site plan with building corner; red outline marks building corner.
Floor plan of a house with sofa, dining table, piano, kitchen, bathroom, bedroom, garage.
Floor plan of a house with kitchen, dining area, living room, bedroom, bathroom and garage.
Floor plan of a house with garage (2 cars), open living/dining area, kitchen, bathroom and hallway.
Site plan of plot with house, garage (2 cars), terrace with umbrella and chairs.
DerBer1
10 Dec 2023 21:05
Aerial photo attached. I was no longer able to add it afterwards using the edit function.
Aerial view of a green field landscape, village on the right with red roofs, road in the foreground.
kbt09
10 Dec 2023 21:18
General recommendation: always align all site plans and floor plans consistently.
Where is the upper floor plan?
11 Dec 2023 00:20
With a budget of €900,000 including taxes and fees, you can get a nice house on this plot despite the restrictive regulations.
Additional construction-related costs of €50,000, €50,000 for paving, €50,000 for the garden and garage, and about €50,000 as a contingency should be considered.
For €700,000, you can afford roughly 200–220 sqm (2,150–2,370 sq ft) of living space. Alternatively, you could opt for less living area with a utility basement (in case of KfW 40 standard).
There should definitely be room for two children's bedrooms on the upper floor alongside a master suite—you can even achieve this on about 140 sqm (1,500 sq ft) with a single-story design plus attic conversion.
What you seem to be getting wrong is not planning efficiently with the available square meters, but simply applying a standard floor plan onto the 10 by 12 meter (33 by 39 ft) plot and sketching from that as your design.
Let me put it this way: with your budget, you can also afford an architect who will maximize the potential of the site.
11ant11 Dec 2023 00:35
DerBer1 schrieb:
The goal is to get an idea of how much living space is needed when all desired rooms are included, in order to create a cost estimate.
I always try to limit myself to about 10x12 m (33x39 feet) so that the total living area doesn’t get out of hand.
However, I always reach the limits when trying to include both a guest room and the grand piano on the ground floor. It shouldn’t feel cramped. I definitely don’t want to go bigger since we don’t need the space on the upper floor.
Read your own words and realize: the grand piano will end up on the upper floor. But most likely not in a self-designed layout.
A 120 m² (1290 sq ft) footprint will result in approximately 190 m² (2045 sq ft) of living and usable space over two stories.
By the way, professionals usually design the upper floor first.
DerBer1 schrieb:
I am probably too fixed on the floor plans mentally, so a push in a completely different direction wouldn’t hurt.
Then don’t think about floor plans at all for several weeks.
DerBer1
11 Dec 2023 20:12
kbt09 schrieb:
Where is the first floor plan?
Yes, that's a valid question. I know the first floor is more important, but the crucial point is whether the wing needs to be on the first floor or if there is space for it on the ground floor. To answer that, I first worked on the ground floor.
