ᐅ Looking for recommendations on terrace separation for a semi-detached house
Created on: 27 Apr 2021 20:46
C.beckmann1986
since we have made some progress with the terrace, we are now moving on to planning the partition wall.
A brief introduction: we have decided on a concrete slab with a wood-effect finish from Kann. This will be framed all around.
The landscaper would like to install a terrace divider right away. According to him, it would be difficult to do this later because the terraces (semi-detached houses) will be framed, and the edging would have to be damaged again in order to properly anchor the partition wall.
However, since the landscaper’s prices for the partition wall are quite steep, we would prefer to do this ourselves later, after consulting with the neighbor. So here are my questions:
1. Is it really that “difficult” to install the partition wall later once the terrace is complete? Of course, I would prefer not to “ruin” the landscaper’s work.
2. What type of partition wall do you recommend? Ultimately, we have only one neighbor since this is a corner lot.
We had looked at something made of WPC (wood-plastic composite). However, that is probably not the best solution in terms of sound insulation.
On the other hand, a masonry wall is likely to heat up significantly in summer.
We are somewhat uncertain and open to ideas and advice. What works well with a terrace that has a wood-effect finish?
If he doesn’t overdo the back support for the curbs, you can easily install a WPC fence later on. Just leave about 20-30cm (8-12 inches) of space between the terraces. Otherwise, you can simply knock off the support at the relevant spots to embed the posts in concrete. Ideally, you already know where the posts will be placed so he avoids putting back support there. With a 1m (3 ft) concrete curb, you still have 70-80cm (28-31 inches) of back support, which is more than enough.
A wall looks best visually but costs significantly more than a fence.
In my opinion, the wall heating up is negligible. At 30°C (86°F), a WPC fence also gets warm. I have never heard of anyone considering thermal insulation for a partition wall.
pagoni20203 May 2021 13:20For me, in addition to privacy screening, soundproofing is also important so that neither side has to whisper all the time. Of course, this depends on the local conditions, but a single-layer solution offers little protection. Perhaps you could plant a dense hedge together or add one; furthermore, there are various solutions using materials like mineral wool, cork, and others to reduce noise. I simply find it uncomfortable on both sides to hear every word the other person says, and vice versa.
Naturally, you will always hear your neighbors when living this close, but especially on the terrace, I want to be able to have a reasonably "free" conversation.
C.beckmann19863 May 2021 13:40That was my thought as well. So the wall is probably the best solution, right?
Regarding WPC, given the southwest orientation of the garden, I also see the issue that it will eventually discolor due to UV exposure. Or is that something that can be neglected?
pagoni20203 May 2021 13:55A nice wall also makes sense, and you can then plant on either side or take other measures for sound insulation. Ultimately, you should try to find a joint solution if possible.
C.beckmann1986 schrieb:
I also see the issue with WPC due to the southwest orientation of the garden, that it will still discolor over time because of UV light.WPC discolors less than wood, but its sound insulation is like a wooden plank fence. For sound insulation, a solid wall is best, and you should leave no gap below the roof.
If your neighbor laughs loudly, it can get annoying over time.
C.beckmann19863 May 2021 16:04Nida35a schrieb:
WPC discolors less than wood but provides sound insulation similar to a plank wall.
In terms of soundproofing, a solid wall is best, and you should leave no gap at the top under the roof.
If your neighbor laughs loudly, it can become annoying over time. What do you mean by “leave no gap at the top”? I'm a bit confused.
