Plot Size: 525 m² (5650 ft²)
Slope: No, the plot has a diagonal height difference of about 0.5 m (20 inches)
Site Coverage Ratio: 0.4 = 210 m² (2260 ft²)
Floor Area Ratio: 0.6 = 315 m² (3390 ft²)
Building Envelope, Building Line and Boundary: Only the usual edge setbacks and about 5 m (16 ft) from the street
Edge Development: Planned carport
Number of Parking Spaces: 1 up to 100 m² (1075 ft²) of living space, above that 2
Number of Storeys: Ground floor + attic
Roof Style: Required roof pitch 35°–45° (flatter pitches would likely be exempt)
Architectural Style: Not strictly defined, mainly determined by roof requirements
Orientation: Almost perfectly north-south oriented, rotated about 5°
Maximum Heights / Limits: Ridge height 9 m (29.5 ft)
Additional Requirements: None really, apart from planting regulations
Owners’ Requirements
Architectural Style, Roof Form, Building Type: “Normal house,” 1.5 storeys, bungalow is simply too large for the plot
Basement, Number of Storeys: Slab-on-grade, 1 to 1.5 storeys
Number of Occupants: Currently 1 person, mid-30s
Space Requirements on Ground and Upper Floor: About 100 m² (1075 ft²) total to leave some room for flexibility
Office: One room desired as an office for home or family use
Overnight Guests per Year: Not many, guests can sleep on the sofa if needed
Open or Closed Layout: Rather closed
Conservative or Modern Construction: Rather conservative, prefer larger roof overhangs than trendy modern styles
Open Kitchen, Kitchen Island: Semi-open, possibly an island as a half-height room divider
Number of Dining Seats: Table comfortably seats 4 daily, expandable to 10 for guests
Fireplace: No, maybe added later as an external chimney
Media / Stereo Wall: Media wall with TV and other equipment
Balcony, Roof Terrace: No
Garage, Carport: Carport with 1 parking space plus integrated storage shed (second parking space in front of carport)
Utility Garden, Greenhouse: Mostly lawn, shrubs, fruit trees, maybe 1–2 raised beds
Other Wishes / Special Features / Daily Routine, including reasons why certain things should or should not be included: ---
Who Designed It: Original design from a catalog, second draft with minor changes from the original
What Do You Like Most? Why? The room layout suits me. I don’t need anything extravagant
What Do You Like Least? Why?
Estimated Price According to Architect/Planner: None yet
Personal Budget for the House, Including Equipment: 250,000 excluding land, outdoor facilities, carport, kitchen, photovoltaic system
Preferred Heating Technology: Underfloor heating combined with an air-to-water heat pump, solar panels on the roof, possibly KFW40+ (energy efficient standard)
What Is the Most Important / Basic Question Regarding the Floor Plan, Summarized in 130 Characters?
I would like the large open living-dining-kitchen area with doors from the stairwell/hall
Do you see any rooms that are way too small?
The knee wall is 1 m (3.3 ft), roof pitch 40°
Attached Are
Oh, and the roof ridge runs left to right → perfect south side for solar panels
What do you think?
Attached Are
- Plot plan with placement idea
- Ground floor and upper floor plans as in catalog
- Ground floor and upper floor plans with my small modification ideas
- Ground floor: smaller WC (no shower needed there)
- Ground floor: front door with side glass panel
- Ground floor: utility room approx. 1 m² (11 ft²) larger
- Ground floor: access to utility room not through kitchen (it is the mudroom; I don’t want to pass through the kitchen)
- Ground floor: door between hall and kitchen
- Ground floor: challenge – how to get a door between the stairs and living room
- Upper floor: bathroom modified, larger walk-in shower by “building over” the staircase opening
- Upper floor: bathroom door shifted
- Upper floor: rearranged remaining bathroom elements
- Upper floor: wall between the lower rooms shifted “to the left,” making room 2 about 1.2 m² (13 ft²) bigger; could be better as a children’s room or alternatively my office, with the left room used as storage or possibly the office
What do you think?
Wandervogel85 schrieb:
Oh, the roof ridge runs from left to right.Is that a requirement according to the development plan / building permit? The catalog house is the Point 109, are you also planning to build with Danwood? Do you know the actual prices, not just the catalog prices but the final costs?
Are you planning to have children or do you want to live alone forever? Design your house accordingly, just like your lifestyle. If you are a single person who enjoys gardening, I would rather build a model like the Perfect with an attic. If you anticipate that there might be changes in the future, I would generally wait before starting the build. If you don’t rule anything out but for now want to plan for yourself without expectations, I would also recommend the Perfect with an attic that can be expanded later.
I don’t see the shower implemented in timber frame construction, only in solid construction. Don’t ask me why. It’s a gut feeling.
Your ground floor plan removed the cloakroom. Is that such a good choice?
Ground floor: access to the technical room not through the kitchen (That’s the utility / maintenance room, I don’t want to go through the kitchen)These days, the technical room is not a dirty room. Where are you going to do the laundry? Exactly: in the cleaning room 😉 So it will be as clean as you keep it. For me, the rooms are too small, yes.
I used to live alone in 86sqm (roughly 920 sq ft) with two large rooms. No dedicated waste rooms at all... I’d say that the 11sqm (roughly 118 sq ft) have sloped ceilings, so you can actually use a bit less area. None of these rooms works really well as a gym, except for mattress sports, like floor-based yoga or so 😉
What are you planning to use the rooms for? Storage and office?
Carport with one parking space + integrated shed (the second parking space would be in front of the carport)Officially, that does not count as a parking space. Nobody is allowed to block it.P
Pinkiponk1 May 2021 09:54ypg schrieb:
That officially does not count as a parking space. It must not be blocked by other vehicles.Oh dear, if that is a regulation in every federal state, we will probably have to prepare for another rejection of our building application. Our plan is the same: carport with a parking space in front, and in front of that the required minimum distance from the street.Wandervogel85 schrieb:
This is also a heating issue since the living room is the warmest place in the house and the stairwell the coolest. But how can I get this properly sorted? Everything basically has a temperature, except for a room that is deliberately kept closed. The ground floor (GF) is not suitable for that.
The door is right in the middle of the room without a wall to serve as a stop. A door stop? That’s not necessary... a door wouldn’t be a problem, but...
Sliding door? Where?
... skip the door; it’s not needed in that small section alone. Close the opening with drywall, if desired, or a stylish room divider...
Basically, I think the house is poorly positioned. I would pay more attention to the afternoon sun.
Pinkiponk schrieb:
Carport and parking space in front, then the required minimum setback from the street.Do you need two parking spaces according to the building authority?Otherwise, I would consider a diagonal layout.
By the way, it’s really annoying to switch cars multiple times a week, although it often is necessary. I find the situation quite complicated compared to others, rather restrictive, and also environmentally unfriendly. I don’t want to imagine how many people still make short trips to switch cars or go to the bakery, yet want to comply with KfW 40 standards (is that still the term?).
Wandervogel851 May 2021 10:22ypg schrieb:
Is this a requirement according to the development plan (building permit/planning permission)?
The catalog house is the Point 109, are you also planning to build with Danwood? Do you know the actual prices, not the catalog prices but the final costs?
Are you planning to start a family or live alone forever? Design your house accordingly, just like your lifestyle habits. If you’re someone who enjoys gardening and lives alone, I would rather build a Perfekt model with a roof attic. If there’s a chance that something might change, I would wait before starting construction anyway. If you don’t rule out anything but want to plan for yourself alone at first without expectations, I would also prefer the Perfect model with an expandable attic.
Your layout on the ground floor removed the wardrobe. Is that really a good idea?
The utility room nowadays is no longer a “dirty room.” Where will you do the laundry? Right: in the cleaning room 😉 So it will be as clean as you keep it.
I used to have 86 sqm (about 922 sq ft) living alone with two large rooms and no dedicated storage rooms at all… I’d say the 11 sqm (118 sq ft) rooms are under sloped ceilings, so usable floor space is actually less. As a home gym, none really works well except for mattress exercises close to the floor, like yoga 😉
What do you want to use the rooms for? Storage and office?
That does not officially count as a parking space. None of the spaces may be blocked by parked cars. No, the development plan does not specify the ridge orientation. However, since the plot is almost perfectly aligned north-south, that almost dictates the layout. I think the room orientation as currently drawn is not bad. Sleeping in the northeast. Living room in the northeast with windows facing south. Office facing the street, possibly a children’s room overlooking the garden.
The adjoining gardens to the north and east are huge, so I’m not squeezed in. On the opposite side of the street, there is a noise barrier mound for a rarely used soccer field (about one evening per week). So I won’t be overlooked there either.
I also had the same thought about the wardrobe. But I find the door to the utility room better placed in the hallway. Plus, that way I can add some countertop space in the kitchen where the utility room door was before.
And before this is suggested: I prefer direct access from the hallway to the kitchen. I don’t want to carry all groceries through the living-dining area. Nor do I want to have to pass through the kitchen to get to the living room. I wouldn’t change that.
The use of rooms should be quite logical with so few rooms:
1x bathroom
1x bedroom
1x office, which could be converted to a children’s room, hence the enlargement compared to the original floor plan
1x storage room, which could become an office if it changes into a children’s room
I honestly can’t imagine why anyone needs a dedicated home gym. Sports should be done outside, and if needed, a stationary bike could stand in the office (or serve as a substitute for the infamous “chair” in the bedroom). Likewise, I don’t see the point of a separate walk-in closet. That’s just a matter of personal taste.
If the space in front of the carport does not count as a second parking spot, it is even more important to know which living area is considered for the parking space requirement. According to DIN 277, it should be about 110 sqm (1,184 sq ft); according to the Residential Space Ordinance, it must be 99.x sqm (about 1,066 sq ft).
Where?
… skip the door, you don’t need it in such a small area alone. Close the opening with drywall if desired or a stylish room divider...
In principle, I find the house poorly positioned. I would pay more attention to the late afternoon sun. Sure, no door needed there. But it would be important to me.
How would you position the house?
I like the gable facing the street. It makes the house look normal-sized and not too small. The house is actually a pretty standard width, just somewhat short in depth.
I’m aware of the evening sun issue, but I also don’t want the terrace at the front of the house or sit facing the street.
