ᐅ 100m² House Floor Plan – Too Small?
Created on: 30 Apr 2021 23:46
Wandervogel85
Plot Size
: 525 m² (5650 ft²)
Slope: No, the plot has a diagonal height difference of about 0.5 m (20 inches)
Site Coverage Ratio: 0.4 = 210 m² (2260 ft²)
Floor Area Ratio: 0.6 = 315 m² (3390 ft²)
Building Envelope, Building Line and Boundary: Only the usual edge setbacks and about 5 m (16 ft) from the street
Edge Development: Planned carport
Number of Parking Spaces: 1 up to 100 m² (1075 ft²) of living space, above that 2
Number of Storeys: Ground floor + attic
Roof Style: Required roof pitch 35°–45° (flatter pitches would likely be exempt)
Architectural Style: Not strictly defined, mainly determined by roof requirements
Orientation: Almost perfectly north-south oriented, rotated about 5°
Maximum Heights / Limits: Ridge height 9 m (29.5 ft)
Additional Requirements: None really, apart from planting regulations
Owners’ Requirements
Architectural Style, Roof Form, Building Type:
“Normal house,” 1.5 storeys, bungalow is simply too large for the plot
Basement, Number of Storeys: Slab-on-grade, 1 to 1.5 storeys
Number of Occupants: Currently 1 person, mid-30s
Space Requirements on Ground and Upper Floor: About 100 m² (1075 ft²) total to leave some room for flexibility
Office: One room desired as an office for home or family use
Overnight Guests per Year: Not many, guests can sleep on the sofa if needed
Open or Closed Layout: Rather closed
Conservative or Modern Construction: Rather conservative, prefer larger roof overhangs than trendy modern styles
Open Kitchen, Kitchen Island: Semi-open, possibly an island as a half-height room divider
Number of Dining Seats: Table comfortably seats 4 daily, expandable to 10 for guests
Fireplace: No, maybe added later as an external chimney
Media / Stereo Wall: Media wall with TV and other equipment
Balcony, Roof Terrace: No
Garage, Carport: Carport with 1 parking space plus integrated storage shed (second parking space in front of carport)
Utility Garden, Greenhouse: Mostly lawn, shrubs, fruit trees, maybe 1–2 raised beds
Other Wishes / Special Features / Daily Routine, including reasons why certain things should or should not be included: ---
Who Designed It:
Original design from a catalog, second draft with minor changes from the original
What Do You Like Most? Why? The room layout suits me. I don’t need anything extravagant
What Do You Like Least? Why?
Estimated Price According to Architect/Planner:
None yet
Personal Budget for the House, Including Equipment: 250,000 excluding land, outdoor facilities, carport, kitchen, photovoltaic system
Preferred Heating Technology: Underfloor heating combined with an air-to-water heat pump, solar panels on the roof, possibly KFW40+ (energy efficient standard)
What Is the Most Important / Basic Question Regarding the Floor Plan, Summarized in 130 Characters?
I would like the large open living-dining-kitchen area with doors from the stairwell/hall
Do you see any rooms that are way too small?
The knee wall is 1 m (3.3 ft), roof pitch 40°
Attached Are
  • Plot plan with placement idea
  • Ground floor and upper floor plans as in catalog
  • Ground floor and upper floor plans with my small modification ideas
    • Ground floor: smaller WC (no shower needed there)
    • Ground floor: front door with side glass panel
    • Ground floor: utility room approx. 1 m² (11 ft²) larger
    • Ground floor: access to utility room not through kitchen (it is the mudroom; I don’t want to pass through the kitchen)
    • Ground floor: door between hall and kitchen
    • Ground floor: challenge – how to get a door between the stairs and living room
    • Upper floor: bathroom modified, larger walk-in shower by “building over” the staircase opening
    • Upper floor: bathroom door shifted
    • Upper floor: rearranged remaining bathroom elements
    • Upper floor: wall between the lower rooms shifted “to the left,” making room 2 about 1.2 m² (13 ft²) bigger; could be better as a children’s room or alternatively my office, with the left room used as storage or possibly the office
Oh, and the roof ridge runs left to right → perfect south side for solar panels
What do you think?
Wandervogel85
12 May 2021 22:38
Andre77 schrieb:
@Wandervogel85
At Danwood, the foundation slab is an additional cost, as they build starting from the top edge of the foundation slab.
Yes, I'm aware of that. It has already been estimated at around 22,000 EUR. Of course, I will also request separate quotes for that.
Andre77 schrieb:
I only have about 100 m2 (1,076 sq ft). Take a look at the floor plan of the Alto S10 D from Heinz von Heiden. I made some slight changes to the ground floor to create more storage space. By the way, this change didn’t cost anything. In the bathroom, I specified a shower measuring 90 x 120 cm (35 x 47 inches) with a 2 cm (0.8 inch) shower tray. The original length was 10.20 m (33.5 ft), which I reduced to 9.7 m (31.8 ft). The eaves overhang on the side is just under 1 m (3.3 ft), which is close to what you’re considering.
Maybe this is a little inspiration for your planning.
Thanks, I hadn’t considered that manufacturer before because I thought they only operated in the North. I’ve now taken a look. The Alto S10 D is no longer available. At first glance, I like the Alto 410 there. I’ll have to take a closer look.
I also requested information about the Town & Country Raumwunder 100. The “South” variant is roughly what I want, but it would still need some adjustments.
In terms of the floor plan, I like the Bien-Zenker Evolution 122 V2 and V3. I have a meeting about that on Monday.
12 May 2021 23:44
Wandervogel85 schrieb:
Town & Country Space Miracle
Do you need a space miracle as a single person or possibly with a partner?
Wandervogel85
13 May 2021 00:20
I can’t do anything about the name.
The layout is similar to the Point 109.1 model from Danwood.
The roughly 100m² (1,076 sq ft) provide a bit of extra space, regardless of how it’s used later.
Houses around 85m² (915 sq ft) would be the perfect size for me right now. But that leaves no real flexibility if life changes. Storage space also becomes tight quickly. I don’t have many things, but over time some items naturally accumulate—from Christmas decorations to sports equipment to tools, and so on.
13 May 2021 01:14
Space-efficient homes are characterized by their ability to comfortably accommodate four people within a small area. For a single occupant, for example, you could forgo one room (such as a child's bedroom) and instead plan for more spaciousness and openness. Just because one or four people need storage space for various items doesn’t mean that half of the house has to be used for storage. It’s also important to consider potential future needs. What if you design as many rooms as possible upstairs, but next month you become unable to use the stairs? Didn’t you mention that you actually don’t want children? I would suggest first designing a house for yourself (if that’s the case). A home suited for one person can also accommodate two. If the situation changes significantly, you can always adjust your plans together.
11ant14 May 2021 00:33
My reading recommendation regarding closely following the related topic is: https://www.hausbau-forum.de/threads/t-c-raumwunder-100-mit-wenig-Änderungen.39200/ – the same "space saver" is being discussed here, even with a similar modification request.
Wandervogel85
14 May 2021 00:40
Thank you. I have actually seen that as well.
