ᐅ Construction Report Single-Family Home €1200 per m²
Created on: 14 Jun 2020 12:05
hegi___
This is the construction report following an earlier thread on floor plan design.
Planned are:
618 m² (6650 sq ft) plot of land
150 m² (1615 sq ft) living space
50 m² (540 sq ft) double garage
Air-to-water heat pump with underfloor and wall heating
Zehnder ventilation system
Exterior blinds in the living room, kitchen, and gallery. Windows anthracite on both inside and outside
Smart home wireless Homematic IP
Planned budget: €300,000 including land and ancillary costs + €30,000 reserve
Plus €12,500 net for a 9.6 kWp photovoltaic system financed separately
Only small regional companies recommended by other builders are being considered.
So far, the following trades have been contracted:
Earthworks: €20,000
Shell construction: €73,000 + €1,000 for the porch above the front door, Wienerberger Poroton T9
Roof: €19,000 + €1,500 scaffolding
Electrical work: €11,000 excluding chiseling work
Window materials: 17 Salamander triple-glazed units + Beck & Heun roller shutters + 5 Selt exterior blinds = €16,000
Quotes received for:
Plastering without decorative finish: €21,000
Bathroom ceramics Villeroy & Boch: €3,000 from Reuter Bathroom Shop
Interior doors Herholz: €2,600
Hörmann front door + garage door: €3,000
Building services materials from the internet: €10,000
Zehnder ventilation unit ComfoAir Q350 TR enthalpy heat exchanger including materials: €4,000 from Selfio
Nobilia kitchen furniture: €5,500, Bosch Series 4 kitchen appliances from Für Uns Shop with 50% discount for €3,500
Modern white villa with dark pitched roof, carport, two cars and front garden.
3D visualization of a modern white house with grey roof, garden and driveway.
Floor plan of a house with kitchen, office, hallway and WC as well as color-coded wiring.
Floor plan of a house with bedroom, child 1, child 2, dressing room, hallway, bathroom and stairs.
Architectural plan: two-story house with floor plans, sections and elevations.
Architectural plan of a house with front, rear, north and south views including measurements.
Construction cost breakdown with land, interim and building costs as well as own work.
Sparfuchs77
4 Dec 2020 11:23
hegi___ schrieb:
Hydronic towel warmers no longer have a place in new buildings either.
Why?
O
Octrineddy
4 Dec 2020 11:41
...The commonly installed underfloor heating system is a low-temperature system (for energy efficiency), which is not compatible with the water-based towel radiator. This radiator usually requires a significantly higher flow temperature.
I
icandoit
4 Dec 2020 12:04
Octrineddy schrieb:
...The commonly installed underfloor heating system is a low-temperature system (for energy efficiency), which does not work well with a hydronic towel radiator. The latter typically requires a significantly higher supply temperature.
Is that why there are two heating circuits?
Lumpi_LE
4 Dec 2020 12:25
icandoit schrieb:
Why are there two heating circuits?
Having 50°C (122°F) at your feet and 40°C (104°F) in the room is just not for everyone.
Schimi17914 Dec 2020 12:32
That's how it is with us (still oil heating).
O
Octrineddy
4 Dec 2020 12:32
The energy source would first need to provide a high temperature, which is then artificially reduced for the underfloor heating --> efficiency goes down the drain 😉
