ᐅ Retaining Wall: What Are the Different Types?
Created on: 5 May 2020 08:07
Grantlhaua
Of course, you can find many ideas for retaining walls on Pinterest, but most of them are not from an average everyday garden. Do you have retaining walls on your property, and if so, what do they look like?
I need a slope support behind the garage about 1.5m (5 feet) high and a retaining wall for the terrace that should be about 1m (3 feet) high...
manohara5 May 2020 14:28
... and beyond formwork construction, this extends to sculptures ...
(this piece was modeled from concrete)
Large bear head sculpture, half buried in the ground, paint pots and ladder in front of playground in the background.
Grantlhaua
5 May 2020 14:33
However, when it comes to integral coloring, I am concerned that the color might not distribute evenly. With the hollow concrete blocks, I also worry that the mortar could deteriorate over the years...
manohara5 May 2020 15:05
I believe achieving an even distribution is not difficult because the concrete is mixed in a concrete mixer, which automatically disperses the pigments.
There are also methods to create intentionally varied coloring.
When adding color, you need to use pigments that are compatible with cement. As far as I understand, only “soft” colors are possible because concrete cannot tolerate too many pigments... but you should definitely consult someone with expertise on this. I have only heard about it and find it interesting.
I have also seen concrete where the surface was later mechanically roughened. This is another option that, in my opinion, can make it look “good.”
haydee
5 May 2020 15:26
We still have an old concrete wall – unfortunately, not all the inherited walls are made of sandstone. As children, we were never allowed to throw snowballs at the wall because the plaster would fall off. And that’s exactly what happened. The wall was last plastered in the mid-1980s. The plasterer said it used to be like that. We only had it plastered in 2019, so I can’t really tell if that’s true.
hampshire
5 May 2020 15:45
How about greywacke?
Garden with natural stone wall, gravel path, and sloped terrain
Grantlhaua
6 May 2020 11:07
[ATTACH alt="7E2874C9-058D-4115-A96B-473DE9D53FB5_1_201_a.jpeg"]46557[/ATTACH]
To be honest, I'm not a fan of it visually.
