ᐅ Fence Construction – Installing Posts on an Uneven Sandstone Wall?
Created on: 19 Mar 2020 14:48
Changeling
We have a sandstone wall made of thick, irregularly split blocks. It looks great, but what is the best way to install our fence there? We have standard welded wire mesh panels with corresponding posts for screwing on. Has anyone faced this challenge before? On one hand, the stones are not all the same height, and on the other hand, the relatively small base plate sometimes sits unevenly on the irregular stone surface.
Neubi-BY22 Mar 2020 10:35
Changeling schrieb:
A good idea! But up to what height would this work? The panels are 2.50m (8 feet 2 inches) long and 1m (3 feet 3 inches) high. The sandstone shows differences of more than 5cm (2 inches) along the entire length, so in the worst case, such a "mortar base" can become quite high.
Why are you only considering the appearance of the base itself?
What really matters is how the entire fence looks afterward. It should be straight horizontally. Also, it shouldn’t look like a snake shape from the side. For that, it is important that all the bases are at the same height and aligned laterally.
And one more thing:
It doesn’t help to make the base or the whole post lower than the highest point of the wall – unless you want to shorten all your wire mesh panels?
Changeling
22 Mar 2020 20:53
Neubi-BY schrieb:
What really matters is how the entire fence looks in the end. It should be perfectly level horizontally. Also, it shouldn’t look wavy or like a snake when viewed from the side. Therefore, it’s important that all posts are set at the same height and aligned laterally.
And one more thing:
It doesn’t help to set the post base deeper than the highest point of the wall—unless you want to cut all your welded wire panels shorter, right?
Steven schrieb:
But as soon as you cut the posts, that’s where corrosion will start. Or if there’s a small scratch on the powder coating... and so on.
If you haven’t bought anything yet, go for stainless steel, grade V2A or V4A. The higher cost is offset by practically unlimited durability.
Hmm... this seems more complicated than I initially thought.
Would it be an option to sacrifice 20cm (8 inches) of space and cast the fence directly behind the wall or attach it right to the wall with concrete? Something like this, viewed from above:
2D kitchen floor plan with wall unit cabinets and socket markings
The posts marked in red would be placed almost leaning against the wall and then encased with a semicircular concrete surround. The soil behind would need to be well compacted to prevent the fence and concrete from toppling over. Would that work?
The advantage would be cheaper posts (no freestanding base plate) and less complex leveling.
Or would it just look very awkward?
Steven
23 Mar 2020 08:56
Changeling schrieb:
Would it maybe be an option to sacrifice 20cm (8 inches) of space and simply pour the concrete for the fence directly behind or attached to the wall? Like this
Hello changeling
That is probably the simplest solution.
However, I would leave a few centimeters of space between the wall and the fence. About 10cm (4 inches), drill holes or dig out the ground. Make the posts a bit longer. Align them plumb and set them in concrete. You plan to plant a hedge along the fence anyway.
Steven
Changeling
23 Mar 2020 09:48
Steven schrieb:
In that case, I would still leave a few centimeters of space next to the wall.
What’s the reason behind this? I want to minimize wasted space as much as possible, even though there will be a hedge there (which shouldn’t grow directly under the fence).
Steven
23 Mar 2020 09:57
Changeling schrieb:
What is the background?
Hello Changeling,
dirt will collect between the wall and the fence, as well as moss and plants.
With a gap of 10cm (4 inches), you can pull it out from the street side. If you work directly at the wall, you will need pliers and tweezers.
Steven
dab_dab
23 Mar 2020 10:20
Alternatively, with slightly more material usage:
According to the method described in post #2, align crossbeams horizontally along the entire length on each side, and then mount the posts on them.
