ᐅ Single-family home designed by an architect, 150 m² – looking for improvement suggestions and ideas
Created on: 2 Oct 2019 10:32
DimaNDS
Lot size: 528m² (5679 sq ft)
Slope: no
Site coverage ratio: 0.3
Floor area ratio: 0.45
Building window, building line and boundary: Roof ridge direction E/W
Edge development: Garage max 15m (49 ft)
Number of floors: 2
Roof type: Gable roof
Orientation: S/W
Maximum height / limits: 9m (30 ft) ridge height
Other: Sound insulation class IV
Style, roof type, building type: Modern
Basement, floors: no basement, ground floor, upper floor, partial attic
Number of occupants, age: 4
Room requirements ground floor, upper floor: Ground floor living room, kitchen, guest room, office, guest WC, storage room; upper floor 2 children’s rooms, master bedroom, bathroom
Office: family use or home office: both
Overnight guests per year: 10
Number of dining seats: minimum 6
Fireplace: no
Music/stereo wall: no
Garage, carport: double steel garage with utility room, 6 x 9m (20 x 30 ft)
Vegetable garden, greenhouse: no (bed in front of kitchen)
Planning by: Architect
What do you particularly like? Why?: We love the openness of the house.
What do you not like? Why?: We really like the design, but we’re unsure if there might be issues with the technical installations in the attic. Also, access to the attic is via a door in the gable, which might look a bit odd. The architect designed a shelf/ladder construction here. Possibly there is too little storage space for items not used regularly, like Christmas decorations.
Price estimate by architect/planner: €330,000 (including exterior landscaping and kitchen)
Personal price limit for house, including fittings: €350,000
Preferred heating technology: Gas or heat pump, depending on whether sound insulation class leads to a KFW 55 house standard. We still need to get advice on this.
If you had to give up something, which details/extensions
-could you do without: walk-in closet
-could you not do without: the general openness of the house.
Which wishes were implemented by the architect? Bedroom facing east, living room facing west, evening sun in the kitchen.
What makes it especially good or bad in your eyes? Good: It is not a standard house you’ve seen 100 times in builder catalogs. Bad: Relatively high space wastage due to the openness.
What would you do differently or improve? Have we overlooked anything that could cause problems later?
Unfortunately, I cannot upload PDFs. The dimensions are there as well. For orientation: The living room is exactly 4m (13 ft) wide.
Slope: no
Number of floors: 2
Orientation: S/W
Fireplace: no
kaho674 schrieb:
Sorry, man. But this is one of the worst plots I’ve ever seen here. At least if you need a 9m (30 feet) garage. Setting aside the driveway, have you considered how long your utility lines will be to the laundry room? That’s intense!
The individual kitchen cabinets wouldn’t even concern me right now.I agree with you, it’s not easy.
Given the current situation here, you can’t really choose. There were 1,200 applications for 24 plots. You should be grateful to get one at all.
We have to make the best of it.
If you have any other ideas, please share. I really appreciate how actively involved you all are.
Yes, I figured the demand must be huge.
Have you asked how much the 25m (82 feet) of cables crossing the property are going to cost? Are they already included in the budget?
Have you consciously decided against the south-facing layout with the garage around the corner?
In that case, the cables would be "only" about 15m (49 feet).
I don’t think the original house position is that bad:
Through the northern properties above the garage on the right-hand lot, northwest evening sun can still reach the open yard area during summer.
However, the technical room is worth considering. Is it possible that the utilities might also come from the east, meaning the right side of the plan?
... and clarify whether the ridge really must only run east/west.
Is this something one should maybe consider?
This isn’t the same everywhere, but usually, pipes or utilities should not be built over or covered. That would mean you’d have to extend the design quite a bit around the house. Uff!
That’s why I’m trying here to position the connection near the driveway.
