Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
hampshire31 Mar 2019 22:13Nordlys schrieb:
We tried to create a decent kitchen with a limited budget, under 5,000. I think this attempt has been successful. Great that within that budget, you managed to include both an oven and a microwave separately, installed at a convenient height.H
hampshire31 Mar 2019 22:18blackm88 schrieb:
No, a Ballerina. It’s sold under the name LIVA kitchen. Handleless and painted white with seven layers. You really can’t see any fingerprints or marks on it. It looks elegant and well thought-out. The attached table/extension of the countertop with its clean design adds some warmth. I find the walls without upper cabinets and kept so plain a bit unsettling—as if something is missing there.
