ᐅ Introduction to Our Building Project – Feedback on Construction Costs?
Created on: 24 Nov 2018 08:32
Go4live
Good morning dear forum,
I would like to introduce myself and have a few questions.
We (I am 31 and my wife is 31) plan to build next year in the Münsterland region. It will be an urban villa of about 135 sqm (1450 sq ft) on a 507 sqm (5458 sq ft) plot. We have a notary appointment for the plot in two weeks.
I received several offers for an urban villa; our favorite includes:
Urban villa (solid construction / KFW 55 / geothermal heating) with 135 sqm (1450 sq ft) base price: €274,890.00
Additional costs:
Facing bricks = €7,390.00
Ventilation system with heat recovery = €11,480.00 (The base price includes window frame vents)
Exterior landscaping, about 100 sqm (1076 sq ft) of paving = €7,678.00
Carport with storage room = €13,850.00
Painting work = €6,820.00
Floor coverings on ground and upper floors = €6,650.00
Electric roller shutters = €300 each (We would only install them on the ground floor)
Utility connections = €6,925.00
In rough terms, the house price comes to about €340,000.00
The plot is priced at €170 per sqm, so €86,160.00 excluding notary and other fees.
This brings the total to around €440,000.00
We have about €120,000.00 in equity, plan to include about €90,000.00 in financing, and keep the remaining €30,000.00 as a buffer for the kitchen and upgrades.
Our net income is €5,200 per month, although my wife will receive parental leave benefits for about one more year; after that, our net income should rise to about €5,700.00.
Can anyone tell me if these window frame vents are sufficient? Or should a ventilation system definitely be included?
What do you think about the house costs?
Oh, and the inspection shafts are included with the city 🙂
readytorumble
24 Nov 2018 09:31
Then you won’t get any network/LAN either.
I wouldn’t do without it in a new build (this is widely discussed in many parts of the forum).
You can skip the TAE socket if you have LAN wiring.
If you decide to install LAN, plan double outlets in every room right from the start (except maybe the bathroom).
dhd82
24 Nov 2018 09:36
I would skip the TAE connection (which is a connection for a telephone) and instead use the empty conduit for installing a network cable. However, you should use a double socket directly, which requires a different conduit (M25 instead of M20 as used for a TAE line), but this only costs slightly more.
24 Nov 2018 11:02
Bookstar schrieb:
Forgotten additional construction costs?
Go4live schrieb:
Excavation and disposal are included, but it doesn’t say how much. I’ll ask him again about that.
Read the detailed scope of work carefully. This often only refers to an excavation depth of 30cm (12 inches).
What about the additional construction costs? Are they included in a turnkey house or do they still arise separately in a general contractor house?
What about the garden? Are the paving works, splash protection, or the platform included?
SÄT basin?
Is the external water tap sufficient?
Floor coverings?
However, we shouldn’t be too frugal here if the additional construction costs and utility connections come in with a big lump sum.
Go4live
24 Nov 2018 11:19
As mentioned, I will bring up the earthworks with him again.
I can’t find the platform.
Excerpt from the scope of work
Paving works
"The terrace, driveway, and main entrance area (approximately 95 m² (1,023 sq ft)) will be leveled according to the plan and roughly filled with 0-45mm (0-1.8 inch) gravel, compacted, and paved with rectangular anthracite-colored paving stones.
The residential building will be surrounded by edging stones with a 50 cm (20 inch) wide layer of gravel."
Floor coverings are included, or do you mean whether we can manage with the prices?
Utility connections are also included.
Mycraft24 Nov 2018 11:38
Go4live schrieb:
Can anyone tell me if these window rebate vents are sufficient? Or should a ventilation system definitely be planned as well?
Same here.
Window rebate ventilation and KfW 55 standard—anyone suggesting that really needs to study again. Only with controlled residential ventilation.
Go4live schrieb:
Electric roller shutters = 300 € each (We would only take them on the ground floor if at all)
I’ve never understood the point. The worst are the houses where energy saving is taken to extremes and roller shutters are only installed in bathrooms or similar.
I think roller shutters are essential especially on the upper floors because they allow you to darken rooms without issues for many reasons.
Go4live schrieb:
But it only mentions TAE connection, no LAN port?!
Then there is no LAN, just the basic setup from the 80s/90s with TAE (which no one uses nowadays).
So either upgrade or do your own wiring.
Add satellite cabling and all the LAN devices on top. That could easily add another 1–2 thousand.
Go4live
24 Nov 2018 11:53
Mycraft schrieb:
I have never understood that. Why bother at all? Best to have the houses where they push the savings to the extreme and roller shutters are then only installed in the bathrooms or something like that.
I think roller shutters are absolutely essential, especially on the upper floors, because you can easily darken the rooms for many reasons.
I think we misunderstood each other. Roller shutters are included on every window anyway; I only meant that the electric controls might be installed only on the ground floor.
