ᐅ Front View of an Urban Villa: Hip Roof or Pyramid Roof?
Created on: 19 Oct 2016 11:43
Curly
we are planning a square townhouse (10.49 x 10.49 meters (34.4 x 34.4 feet) plus a rear bay window). According to the building plan, we have to have a hip roof with a 28° pitch. Now we have the choice of which direction to place the small ridge on the roof. So either it faces the front (hip roof towards the street and entrance door) or the front shows a pyramid roof and the ridge faces the garden, with the hip roof visible from the side. Which option looks better? How would you do it?
Sabine
Knallkörper
20 Oct 2016 09:20
If in doubt, I would orient it so that the 80cm (31.5 inches) ridge is not visible from the street.
Bronco
30 Aug 2018 11:13
Hello Curly, we are currently building as well and need to have a hipped roof with a 28° (28°) pitch on our townhouse.
Do you perhaps have a photo of your roof so we can get a visual idea? A 28° (28°) pitch seems quite steep for a townhouse.
Kind regards
Bronco
dertill
30 Aug 2018 12:07
I would have the ridge run in an east-west direction. This way, you have more space on the south side if you want to install solar thermal or photovoltaic systems later on.
11ant30 Aug 2018 19:03
Bronco schrieb:
Do you perhaps have a photo of your roof so that it can be visualized more easily? Because a 28-degree pitch seems a bit steep for an urban villa.
No, it definitely isn’t. But please tell me which floor plan the roof needs to fit in your case.
Regarding the original question (RIP): I have never seen in practice that a ridge is strictly required but at the same time left open as to how it should be oriented. Such a specification is usually given to align house grids consistently.
F
Fuchur
30 Aug 2018 19:36
I haven’t seen that in practice, that a ridge is strictly required but its orientation can be chosen freely. Such a requirement is usually used to align building axes consistently.
Yes, that’s exactly what we just experienced ourselves. The development plan requires “any” hip roof, gable roof, or flat roof. We submitted a building application with a pyramid roof. The building authority demands “any,” “arbitrarily small” ridge or alternatively the application for a variance from the development plan (with extra fees). The orientation of the houses is left open within the building zones.
Bronco
30 Aug 2018 23:48
The exterior dimensions are 10.5m x 9.5m with a roof overhang of about 80cm (31.5 inches) all around.
It was the same for us... The zoning plan requires a gable or hipped roof.
Architect's statement: a pyramid roof is a type of hipped roof.
Building authority: No, the hipped roof must have a ridge.
We have now chosen a ridge of about one meter (39 inches).
