ᐅ Floor Plan Design for Single-Family Home – Ideas Welcome from You
Created on: 23 Jan 2018 11:57
rotihex
We visited a general contractor to get a quote for a single-family house. We received an initial design that, in my opinion, is very good.
My husband still sees room for improvement. He doesn’t like that the kitchen cannot be closed off. Our preference was a kitchen that can be closed with a sliding door to avoid noise disturbance. Unfortunately, this didn’t fit with the floor plan. Separating the living room would be an option, but it would then be quite small—too small for my husband.
Upstairs, the master bedroom could be a bit larger.
Do you have any ideas besides enlarging the floor plan or moving the office to the basement?
Thanks in advance
Development Plan/Restrictions
Plot size – 594m² (6387 sq ft)
Slope – no
Floor area ratio 0.4
Site coverage ratio 0.5
Edge development – yes
Number of parking spaces
Number of storeys – 1.5
Roof shape
Architectural style
Orientation – ridge facing the street
Maximum height/limits – none
Other requirements – none
Architectural style, roof shape, building type – gable roof
Basement, storeys – basement + 1.5 storeys
Number of occupants, age – 5 (41/40/10/8/3)
Space requirements on ground floor and upper floor – 4 bedrooms upstairs, office on ground floor, otherwise the usual
Office use: family or home office? – both
Overnight guests per year – none
Open or closed layout –
Conservative or modern style – conservative
Open kitchen or kitchen island – closed kitchen, preferably with an island
Number of seats at dining table – at least 5
Fireplace – no
Music/stereo wall – yes
Balcony, roof terrace – no
Garage, carport – double garage
Utility garden, greenhouse – no, play garden
Additional wishes/special features/daily routine, including reasons why some things should or shouldn’t be –
- Large closed wardrobe area to avoid clutter
- Access from garage to living space
Who designed it? – Architect of the general contractor
What do you particularly like? Why? – All wishes were well implemented, also planned level access living for the future, good orientation to the sun
What do you not like? Why? – Kitchen cannot be closed off = noise disturbance in the living area
Estimated price according to architect/planner: 370,000
If you have to give up something, which features/extensions
- Can you give up:
- Cannot give up: office
Why does the design look the way it does now? For example
Standard draft from the planner? – first draft according to our wishes
Which client wishes were implemented by the architect? – Access from garage to living space, office, large wardrobe, equally sized children’s rooms
A mix of many examples from various magazines…
What makes it particularly good or bad in your opinion? – coherent design, little hallway, lots of space on a small floor plan, very well thought out.
Thanks in advance
Slope – no
Roof shape
Architectural style
Fireplace – no
- Can you give up:
rotihex schrieb:
The building authority will not approve a dormer. Why not? We're talking about less than one third of the eaves length, and your zoning plan does not seem to specify ridge directions either. It seems to me this question is worth pursuing.
I don’t know how others feel, but I can hardly make out anything on your site plan. How wide is the plot? What are the dimensions of the building area? Is edge construction allowed? Is that a high-rise building at the rear of the garden, or what is it?
I would rotate the current plan, including the garage, 90° counterclockwise and then mirror it if needed. But unfortunately, I don’t know the exact building area.
kaho674 schrieb:
I don’t know about others, but I can hardly make out anything on your site plan. How wide is the lot? What is the size of the building zone? Is edge or perimeter development allowed? Is that a high-rise building at the back of the garden, or what is it?
I would rotate the current plan, including the garage, 90° counterclockwise and then mirror it if necessary. But unfortunately, I don’t know the building zone.You are not alone.
I wouldn’t know which plot is where, nor the street, let alone any measurements.
So the building area is almost the only thing you can really identify, approximately 13 m deep (43 feet). You can’t tell where a road is. The lot was probably subdivided; according to the plan, at the point where its boundary intersects an existing building spanning across four lots (? ? ?) – it’s more like a visual puzzle or a collage of various lines and symbols, typical of zoning plans. This doesn’t clarify anything.
So, the development plan is quite outdated and unfortunately doesn’t allow for much.
The plot is 17.5m (57 feet) wide and 34m (112 feet) long. The building setback line is 5m (16 feet) from the front and extends 15m (49 feet) deep. The ridge direction faces the street. Edge development is permitted.
I cannot confirm what is marked at the back in the development plan. The local conditions differ (existing building will be demolished):
rotihex schrieb:
(Existing property will be demolished) How old is it? I would think carefully, maybe three and a half times, before demolishing a building, especially if the basement is still intact, since the dimensions here seem comparable to the desired house. Therefore, I would consider whether the alternative of "building up from the finished floor level" might be appealing.
