ᐅ Idea for Staircase Layout on the Ground Floor
Created on: 23 Dec 2016 10:23
Thomas1980
Thomas1980
23 Dec 2016 10:23
We are currently planning a house (external walls with aerated concrete 36.5cm (14.4 inches) – internal walls with calcium silicate brick) and are looking for some suggestions on the best placement for the utility room, staircase, and guest bathroom. The living/dining area and kitchen are already decided.
Thank you very much and best regards
kbt09
23 Dec 2016 11:50
You can easily upload image attachments directly into your post here on the forum.
The dimensions are hard to read... and are these interior or exterior measurements? It seems like a mix.
Also, it would be helpful if you read the pinned post and answered the questions accordingly. A staircase also depends on the height of the upper floor (probably a full storey?), the purpose of the upper floor, and so on.
23 Dec 2016 15:40
I believe the individual layers result from detailed planning with almost exact dimensions.
With more precise planning, the layers usually become clear on their own or any tight spots become visible.
Anyway, no one can really read anything in the sketch 😉
Thomas1980
23 Dec 2016 16:44
Hi,
I actually don’t think the sketch is that bad 😉
The exterior dimensions are 11.5 x 9 meters (38 x 30 feet). For the living room, I want a minimum room depth of 4 meters (13 feet), and at least 3 meters (10 feet) in the kitchen. The clear structural height on the ground floor is about 3 meters (10 feet) for us. The question now is which staircase is best to use and how to ideally arrange the guest bathroom and utility room.
Here are the details again from the pinned post;
Plot size approximately 700 m² (7,535 sqft)
No slope
Site coverage ratio 0.15
Floor area ratio 0.4
Building window, building line, and boundary
Edge development
Number of parking spaces 2
Number of floors 2
Roof style gable roof
Architectural style
Orientation north/south
Maximum heights/limits unlimited
23 Dec 2016 17:17
Again: it’s a good idea (and even recommended) to start with a sketch to determine the best locations for main and bedrooms or the kitchen. You’ve already done that very well.
But after that, you can’t proceed without measurements.
A perfect example is your kitchen dimensions: simply stating that the kitchen should be 3 meters (10 feet) wide is pointless. It entirely depends on the kitchen layout. For a galley kitchen, 3 meters (10 feet) might be too much, but if you want a work surface with a central island that can be walked around on all sides, 3 meters (10 feet) would be too little. Also, the placement of the stove, refrigerator, or even the property’s layout matters, to ensure enough clearance in front of these appliances when their doors are open.
And the most important aspect of staircase planning: the upper floor (first floor/second storey)! The staircase connects the ground floor and the upper floor and should be planned first, of course considering how much space is needed on either side to allow for adequate and optimal room layouts.
The dimensions for different types of stairs are provided in the pinned post by @kbt09 and you should have already seen that.
Pumbaa
23 Dec 2016 18:06
Um, a floor area ratio of 0.15 for 700 m2 (7,535 sq ft)? That doesn’t seem to match with a footprint of 11.5 x 9 m (38 x 30 ft), or am I missing something?
