ᐅ Replacing Windows with Roller Shutter Boxes versus Without
Created on: 29 Jun 2018 20:33
DRDRWHO
DRDRWHO
29 Jun 2018 20:33
I have an existing property with older windows and built-in roller shutters.
Now I would like to install new windows and have been considering removing the windows and roller shutter boxes to replace them with larger ones. This should provide better energy efficiency, or am I mistaken?
At some point, mounting external roller shutters is planned.
Thanks and best regards
11ant30 Jun 2018 13:21
DRDRWHO schrieb:
That should result in higher energy efficiency, or am I missing something.
I don’t know, please explain in more detail where this effect is supposed to come from.
DRDRWHO schrieb:
Roller shutters mounted on top are planned to be installed at some point.
Those would, first, protrude outward, and second, they would have to be planned as part of the window installation anyway (right?).
I used to manage a window factory, and I can’t follow your logic.
Alex85
30 Jun 2018 14:42
Weißnicht, erklär´ das mal näher, wo der Effekt herkommen soll.
Does he perhaps have old, uninsulated roller shutter boxes?
In that case, current double glazing would likely be an energy improvement.
I also don’t understand why someone would want externally mounted roller shutters later on. Now would be the right time to avoid this visual compromise.
DRDRWHO
2 Jul 2018 06:34
First of all, thanks for the responses and the food for thought.
My idea was simply to remove the old roller shutter boxes and fill the resulting opening with a correspondingly sized window.
I assume that a newly installed window would be more airtight than an old window with a roller shutter box.
What I didn’t consider is that a subsequently mounted higher roller shutter would still have to be installed over the already taller window.
For me, the cost issue and the timing of expenses play the decisive role. Therefore, airtight comes before dark.
