ᐅ Tilt-and-Parallel-Projection Windows
Created on: 23 Jun 2015 20:06
Partyhupe
Next week we will start building our new KfW 70 house without a mechanical ventilation system. Why without? It’s better to leave that decision to us! A window manufacturer mentioned a window with a parallel ventilation position. At first, we were quite excited about it. But now we are wondering if this 6mm (0.24 inches) gap really makes a difference if the window is left like that all day—does it actually provide effective air exchange?
Perhaps someone already has experience with this.
laemat
24 Jun 2015 09:32
Our windows have this feature as well, but it didn’t incur any extra cost, so it didn’t matter.
I’m not a fan of it; I’m more concerned about wear and tear because the parallel tilt function isn’t rigid but rather “wobbles,” meaning the window is always moving.
It was promoted to us as a ventilation option even in bad weather.
24 Jun 2015 14:07
nathi schrieb:
No, according to the promotional video, only the stale air goes out, but the heat stays inside.
I haven’t watched the promotional video myself, but I did visit two to three independent—and some dependent—websites:
None of them address heat loss.
In short: they only compare it to a tilted window, highlighting the advantage that there is insurance coverage in case of a break-in (which is not provided for tilted windows on the ground floor).
If I conclude from this, the air exchange and heat loss can be equated with a tilted window—of course noting that the parallel ventilation takes longer.
You can also check this yourself, @Partyhupe.
Regards, Yvonne
wrobel25 Jun 2015 10:35
Hello
Well, that is probably just as effective as ventilation systems with fresh-air vents in the exterior wall.
To reduce investment costs, one could alternatively remove the seals between the frame and sash.
Olli
