For some time now, I have repeatedly had the problem that the connectors on my Billy shelves loosen or even come apart completely. This happens especially at points where several shelves meet or when the load is somewhat higher. My question is: Why do connectors on Billy shelves come loose? Is it due to the design, the materials, assembly errors, or are there other common causes? I would like to understand whether this is a known issue and how to prevent it effectively to ensure stability and durability.
The cause of loosening connectors in Billy bookcases is often due to several factors. One important aspect is the design: Billy bookcases are assembled using dowels and connector screws, which can lose their clamping force after repeated stress or irregular assembly.
In addition to assembly errors, such as screws being tightened too loosely or incorrect alignment of the dowels, the material also plays a role. The particleboard is prone to swelling in high humidity, which affects the precision of the connections.
Furthermore, dynamic loads—such as when moving the bookcase or loading and unloading it—cause small movements that gradually loosen the connectors over time. Therefore, regular inspection and retightening of the screws is advisable.
In summary, the main causes can be listed as assembly errors, material-related changes, and repeated mechanical stress.
moklo schrieb:
Why do connectors loosen in Billy bookcases? Is it due to the design, the material, assembly errors, or are there other common causes?
Oh, I know that all too well! The Billy shelves are definitely a real classic, but those connecting pieces can be a bit tricky sometimes 🙂
What helped me was tightening the screws firmly right during assembly and then checking them again after a few weeks. This often happens with furniture, where slight movements cause everything to loosen.
Also, using small washers can help the screws hold better.
Keep at it, you’ll get it sorted! :-)
Exactly – if you move or load the shelf a lot, make sure to check from time to time if everything is still tight!
LUISABEL schrieb:
Dynamic loads, such as moving the shelf or loading and unloading it, cause small movements that gradually loosen the connecting pieces over time.
First of all, it is important to protect the particleboard from moisture, as it can swell and make a secure connection difficult.
Furthermore, I recommend ensuring the screws are tightened with the correct torque – neither too loose nor over-tightened, as this can damage the material.
Additionally, for higher loads, it can help to fix the shelf to the wall to minimize movement that can cause the connectors to loosen.
If all these points are considered, the construction remains stable and the connectors rarely come loose. If in doubt, I recommend following IKEA’s assembly instructions carefully and replacing screws or wall plugs if necessary.
moklo schrieb:
My question is therefore: Why do the connectors come loose on Billy shelves?
