ᐅ Why do MALM drawers often get stuck when closing?
Created on: 26 Feb 2021 19:32
Farapeo
Farapeo
26 Feb 2021 19:32
I have been experiencing an issue for some time with the drawers of my IKEA Malm dresser, which often stick or jam when closing. This is especially noticeable with the larger drawers, which sometimes only close with increased force or after several attempts.
I understand that these pieces of furniture are used frequently and the drawer slides may not be perfectly aligned, but I am surprised that this jamming occurs so often, even though the drawers should operate smoothly.
Are there technical or design reasons that explain why Malm drawers often stick when closing? Or could this be a common assembly problem? If so, what is the best way to prevent it?
I look forward to your assessments and advice!
LEEJU
26 Feb 2021 19:39
Often, the issue is caused by incorrectly adjusted drawer slides or mounting the drawer runners too tightly.
Loosen and readjust them, then check if the drawer sits perfectly level. This usually helps.
lochen
26 Feb 2021 20:04
Hello Farapeo,
The issue with sticking MALM drawers is quite common and has several causes. The MALM series uses metal drawer slides with plastic rollers. If the slides are not properly aligned or the drawer is not inserted perfectly straight, sticking can occur easily.
Additionally, mounting the slide too tightly on the side panel can create pressure on the drawer. The drawer material itself (particleboard) can also warp slightly due to moisture or weight, which can affect smooth operation.
Another point is that MALM drawers do not always have soft-close mechanisms installed or working equally well in all models, so the drawer often closes mechanically, which can lead to unwanted sticking.
My advice: Check for correct alignment, the screws on the slides, and the position of the drawer. Also inspect the rollers for dirt or damage, as worn or damaged rollers can promote sticking.
Hope this helps!
TEOZAR
27 Feb 2021 08:47
Farapeo schrieb:
Are there technical or structural reasons why MALM drawers often stick when closing?
A common cause is insufficient tolerances during material processing. In affordable furniture like MALM, a lot of particleboard is used, which doesn’t warp ideally. The drawer slides also use plastic rollers that can wear down or get slightly dirty over time, which promotes sticking.
lochen schrieb:
The MALM series uses metal drawer slides with plastic rollers. If the slides aren’t perfectly aligned or the drawer isn’t inserted completely straight, sticking can occur quickly.
Assembly is also a key factor: if the screws are tightened too much, the side panels can warp slightly, preventing the drawer from sliding smoothly. Installation errors like uneven alignment of the slides at the front and back also cause this issue.
Additionally, the weight of the contents and the load on the MALM drawer can increase friction, leading to sticking when moving.
In conclusion, sticking when closing is caused by a combination of material, design, assembly, and usage conditions.
GEKAU51
27 Feb 2021 09:12
It’s interesting how many people immediately blame the assembly or materials here.
Let’s be honest: at MALM’s price point, you can’t expect miracles. The drawer sticking is a typical example of compromises in mass production. IKEA relies on inexpensive components and minimal assembly effort, so logic is often sacrificed to cut costs.
Maybe the drawer doesn’t stick because of poor assembly, but because the system is simply designed suboptimally from the factory. Minor adjustments won’t help much; long-term solutions or replacement parts that you have to improvise yourself are more likely needed.
If you really want something reliable and well-made, you should go for more expensive furniture or build it yourself.
REOHEINRIC
28 Feb 2021 13:03
In summary, the MALM drawers often get stuck when closing due to several factors.
First, the materials used, such as particleboard, are prone to warping, which can cause the drawer to become misaligned.
Second, assembly quality plays a crucial role: improperly aligned drawer slides or screws tightened too much can alter the drawer’s movement path.
Third, dirt or wear on the plastic rollers can increase friction due to the load.
I recommend a thorough inspection of the drawer slides for cleanliness and alignment, as well as readjusting screws if necessary using a torque wrench to avoid excessive deformation of the side panels.
Additionally, it is advisable to regularly remove excess weight from the drawers to reduce the load.
This approach is documented in technical forums and confirmed by professional furniture assemblers.
