ᐅ Why do Malm drawers get stuck?
Created on: 11 Jun 2015 08:12
Floka
Floka
11 Jun 2015 08:12
Hello everyone, I have noticed that the drawers of my Malm dressers (Ikea) often stick, meaning they are hard to open or close. My question is: why do Malm drawers tend to stick so frequently? I suspect it might be related to the design or materials, or possibly to the load and usage. Are there known causes such as warping, material swelling due to moisture, or errors during assembly? I am open to any detailed explanations, and I am very interested in the technical background as well.
Noahlu
11 Jun 2015 09:37
That is a very good and precise question, Floka.
Why do Malm drawers stick? In my experience, several factors play a role, which need to be understood clearly. First of all, the Malm series is made from particleboard-based material—usually laminate or melamine—which can easily swell when exposed to moisture. This change in the material often causes the drawers to stick later on, especially when environmental conditions fluctuate.
Furthermore, simple metal or plastic runners are often used. If these are not exactly adjusted or installed, friction can occur that prevents smooth gliding. I also notice in some Malm dressers that the drawer fronts are slightly warped. This can especially be caused by heavier weight inside the drawers.
To explain: warping means that the fronts bend slightly, which combined with limited space on the drawer runners leads to “sticking.”
Finally, it’s worth checking whether the runners are properly lubricated or if dirt has accumulated in the sliding tracks. Sometimes, a simple cleaning and the application of a suitable lubricant (e.g., silicone spray) is enough to fix the problem.
How exactly are the drawers installed in your case, and how are they being used? Have they only recently started to stick, or is this a persistent issue?
Floka
11 Jun 2015 10:45
Noahlu schrieb:
First of all, the Malm series is made from chipboard-based material—usually laminate or melamine, which can swell easily when exposed to moisture.
That actually makes sense. My drawers are in a room that tends to be a bit more humid, especially in winter due to the indoor humidity.
Noahlu schrieb:
To explain: Warping means the fronts bend slightly, which combined with limited space on the drawer slides can cause them to stick.
That was new to me; I always thought a slight misalignment due to poor installation was the main cause.
My drawers were installed as original, and I use them with normal household contents, so no overloading. They have been sticking from the start, but it feels like it has gotten worse over time. Thanks for the pointers, I will try to control the humidity and take a close look at the slides.
Tarbi
11 Jun 2015 11:19
I think it is important not only to accept material issues or assembly as the cause, but also to consider Ikea’s own normative specifications. Why do Malm drawers stick? Because the design is focused on cost efficiency and mass production.
These pieces of furniture are not built for continuous heavy use or demanding conditions. The production tolerances are deliberately generous, which means that differences occur with every individual assembly. This partly explains why the issue of “sticking” is so common, even though many users believe they followed all instructions correctly.
We should also take into account that even the smallest deviation from the recommended weight limits or assembly instructions can affect the fit.
Therefore, I often question the idea that the best quality can be expected with minimal assembly effort. That is an illusion.
Has anyone here checked whether Ikea actually specifies tolerances in their assembly instructions or construction patterns?
O
onfebe
11 Jun 2015 13:02
I can understand how frustrating it is when something sticks, especially when it’s part of something you enjoy using every day. I experienced the same, and it took me a while to fully understand the problem.
Tarbi schrieb:
The design is focused on cost efficiency and mass production.
In a way, that’s true, but I’ve also noticed that furniture changes over time with everyday use. For me, it was important to realize that no dresser is completely static; it reacts to the climate and regular use.
I just wanted to say that this also affects the way it feels to use.
As a tip, consider checking if the drawers are rubbing against areas they shouldn’t be, or if you can adjust the gap of the drawer slides. Sometimes it’s also due to wear on the rollers, especially if the slide is made of plastic.
In the end, I used a light oil and adjusted the slides a bit — now everything works more smoothly, and I don’t have to worry about pulling hard every day.
Keep at it; it’s worth the effort!
Kenton
11 Jun 2015 14:53
Malm drawers often stick due to warped fronts or damaged runners.
Check if the drawers are aligned correctly and if the runners are free of dust.
Sometimes, adjusting the screws on the runners can also help.
Simple but effective.
