ᐅ Has anyone ever transformed Kallax shelving into a room divider with a seating area?
Created on: 3 Jun 2022 10:17
Kilana
Kilana
3 Jun 2022 10:17
I am currently considering converting my Ikea Kallax shelf into a room divider with an integrated seating area. I am particularly interested in practical implementation details: Has anyone here already modified a Kallax so that it functions not only as a room divider but also provides a stable and comfortable seating surface? Important points would be recommendations for suitable materials for the seating surface, attachment methods, stability considerations, and perhaps ideas for cushioning or using additional elements like hinges or folding mechanisms. How did you account for the load (e.g., from regular use as a seat), and what challenges did you encounter during construction? I look forward to your experiences and tips!
Espen
3 Jun 2022 10:51
I built my Kallax as a room divider with a seating surface. I simply placed a wooden board on top, attached it with hinges, and added a thick foam cushion. It is important to secure the board well so that it doesn’t wobble. It can easily support weight without any issues.
SauDietmar
3 Jun 2022 12:06
Hello Kilana,
I find your project very interesting and can share my own experience of converting my Kallax into a room divider with a seating surface.
First, I followed these steps:
1. Choice of seating surface: I used an 18 mm (0.7 inch) thick plywood board because it is sturdy yet not too heavy.
2. Attachment: I fixed the plywood with folding hinges so the seating surface can be lifted up when needed.
3. Load capacity: To ensure the shelf can handle the extra weight, I secured the Kallax at the bottom with strong brackets mounted to the wall. This prevents tipping.
4. Cushioning: I cut foam (about 5 cm (2 inches)) and covered it with durable fabric. The cushioning is attached with hook-and-loop fasteners, making it easy to remove.
5. Additional tips: Make sure to sand the seating surface as smoothly as possible to prevent injuries and ensure comfortable placement.
Common mistakes include using boards that are too thin or fastening the seating surface insecurely—these should definitely be avoided.
Good luck with your project!
Friedrich
4 Jun 2022 08:39
Kilana schrieb:
Has anyone here already modified a Kallax so that it not only serves as a room divider but also provides a stable and comfortable seating surface?
I really like how much thought you put into this beforehand! I don’t have much DIY experience myself, but I’m at least worried that it might not be stable enough and someone could fall while sitting on it. How do you feel about that? Have you tested how much weight the Kallax can hold when sitting on it? Maybe we could also discuss safety aspects here?
SauDietmar schrieb:
To ensure the shelf can handle the extra load, I fixed the lower part of the Kallax to the wall with sturdy brackets.
That sounds like a good idea! I also think it’s important not to put too much pressure on yourself—it’s perfectly fine to improve on your project a few times. 🙂
KARJU
4 Jun 2022 14:03
As an addition: When converting a Kallax unit into a seating room divider, structural stability is crucial. The Kallax shelving is made of MDF panels with limited load capacity, especially across the grain. Using a plywood board as the seat surface is advisable, since plywood consists of multiple veneer layers, providing higher transverse load resistance.
For fastening, I strongly recommend sturdy hinges and additionally securing the unit to the floor or wall with screws. The greatest risk is tipping caused by lateral forces when sitting down.
The design should safely support the load of an average adult (around 80 kg (176 lbs)) with a safety factor of at least 2.
Summary:
- 18 mm (0.7 inch) plywood board as seat surface
- Securely screwed hinges
- Anchoring the unit to prevent tipping (wall/floor)
- Properly attach padding
Besides comfort, I also suggest planning for ergonomics (seat height around 45 cm (18 inches)).
