ᐅ Which type of underfloor heating is healthier?
Created on: 9 Nov 2008 13:01
jklm-1
9 Nov 2008 13:01
Hello, I have a question: which is healthier and why – an electric mat underfloor heating system (electromagnetic pollution) or a water-based underfloor heating system (flowing water—geopathic stress zones)?
Bobo-1
10 Nov 2008 15:17
Definitely water in any case
For me, only a water-based heating system would be an option, since we are already exposed to enough smog from electrical systems and devices. Water is a natural element, so there is no need to worry about potential harm. We have installed it that way in our home as well, and it works really well.
Ralf-1
12 Nov 2008 16:35
Hello
I don’t find either option ideal. I have problems with my veins, and the heat coming from below is not good for me. It always makes my legs feel heavy, and I have to keep my feet elevated. If I had known this, I would have preferred to avoid this type of heating.
Nebel-1
14 Nov 2008 18:15
At first glance, it sounds better to say that a heating system using water is better than one with electricity. But what about underground water veins? Someone came to my place with a dowsing rod and said that you also need to be careful with water.
Dämmunsinn-1
14 Apr 2009 22:39
Hello everyone
Why do you always want to use air as a heating medium? Underfloor heating is the worst type of air heating. The healthiest option for people is radiant heating. With a heating strip installed along the exterior walls, you can forget about insulation and still save 30% energy. CHEAP and SIMPLE!
😱 😱 best regards 😱 😱
Argyle-1
15 Apr 2009 18:13
Dämmunsinn schrieb:
With a baseboard heater along the exterior walls, you can forget about insulation. And still save 30% energy.
I don't quite understand the idea of skipping insulation. The baseboard heater warms the wall (which in this case should probably be a solid wall made of stone due to better heat storage properties), but if the outside is not insulated, then you have a huge cold surface there. It’s a mystery to me how you expect to save 30% energy with that.
