Grobmutant6 Jan 2020 11:57Hello everyone,
We are planning a basement for our new house, which will be used as a utility basement. The technical room (including the heat pump and mechanical ventilation system, etc.) will be located in the basement. The other rooms are intended for storage, a workshop, and storage areas. Actual living use is not planned; however, I can imagine that our children might later use the space for hobbies (music, party room, foosball, etc.) if the climate there is reasonably comfortable. Also, it should not be freezing cold when working in the workshop during winter.
What about ventilation? I have planned a few basement rooms without light wells and was considering possibly connecting them to the mechanical ventilation system if the humidity gets too high.
Now I wonder, how are utility basements commonly insulated nowadays and what effects does each approach have?
- No exterior insulation at all and only insulating the basement ceiling/stairwell? Is it then acceptable for the heat pump and mechanical ventilation system to be installed in the basement? Can the basement be connected to the mechanical ventilation system, or would that completely negate the heat recovery?
- Exterior insulation but no separate heating in the basement?
- Exterior insulation and underfloor heating in the basement?
What temperatures and humidity levels can be expected with the different options? I would be very interested in your practical experience.
Hello Grobmutant,
@fragg is right. For a basic utility basement, the financial effort to insulate it is not worthwhile, since it is supposed to stay cool. If you want to use the basement as living space later on, you will need insulation. However, as mentioned, this should be combined with underfloor heating, which can also be turned off when not needed.
Grobmutant6 Jan 2020 13:27The underfloor heating can of course be turned off, but if the basement were included within the thermal envelope, it would continuously be warmed through the ground floor. This would certainly not be ideal for efficiency.
Grobmutant6 Jan 2020 13:28fragg schrieb:
We have full insulation with underfloor heating and ventilation. Alternatively, we would have needed an enclosed stairwell, but we didn’t want that. This way, we can easily dry laundry in the basement. What exactly does "enclosed stairwell" mean? Wouldn’t an insulated door to the basement on the ground floor be sufficient?
Grobmutant schrieb:
What exactly does "closed stairwell" mean? Isn't it enough to have an insulated door to the basement on the ground floor?Well, open stairwells are currently in style, nice wooden stairs, airy, continuing all the way up. That's how we have it. How would you even implement a door to the basement?Similar topics
