Hello everyone, I am planning to rebuild my IKEA Brimnes wardrobe after disassembling it for transport. Since some screws and connection methods are a bit puzzling to me, I want to make sure I am using the right tools to avoid damage and ensure a smooth assembly process.
My question: Which tools do you think are needed to correctly reassemble the IKEA Brimnes? I already have the IKEA hex key, but perhaps additional tools are required, such as a cordless drill or special bit sets.
I would appreciate a detailed answer that addresses the specifics of the Brimnes – for example, the types of screws used, whether it is better to assemble the frame with a hammer or rubber mallet, and any other tips regarding the necessary tools.
Hey! I would definitely recommend a cordless drill; it saves a lot of stress and is much faster than using just a screwdriver by hand. 😊
The Brimnes isn’t very complicated to assemble, but a rubber mallet is really useful when fitting the back panels or drawer frames—no scratch warnings!
And maybe a small spirit level to make sure everything is perfectly straight after assembly. That’s how I did it, and it worked great.
Additional information: The screws in the Brimnes set are primarily Euro screws, which should be tightened using an Allen key. A cordless drill with a torque clutch is recommended to avoid over-tightening the screws.
A rubber mallet is useful, as gently tapping wooden parts reduces stress and prevents damage.
Optionally, a spirit level can be helpful if the wardrobe is placed on an uneven surface.
The combination of an Allen key, cordless drill with appropriate bits, rubber mallet, and spirit level covers virtually all the requirements for reassembling the Brimnes.
LEEJU schrieb:
A rubber mallet is useful for gently joining wooden parts together.That sounds very important, as I was a bit worried last time about pressing the wooden parts together with a regular hammer.
I have another question: Are there specific points during the assembly of IKEA Brimnes where extra care should be taken? For example, are the drawer slides particularly delicate, or is there more risk of parts splitting on the cabinet frame?
This information would be very helpful for me to know where I should rely on the rubber mallet especially or if any other protective materials are needed.
The advice to handle important parts gently is absolutely correct. The drawer rails of the Brimnes are made of metal and are sturdy, but excessive force from tools should still be avoided.
The cabinet parts made of particleboard with a melamine surface are usually the most delicate – they tend to fray or chip under strong impact or pressure.
Therefore, I strongly recommend working at the joints with a rubber mallet or by gently fitting the parts together without applying force.
Using small wooden blocks or cardboard protection as assembly aids should not be underestimated. This helps minimize pressure marks and material damage.
