Hello everyone, I recently bought a Brimnes bed from Ikea and noticed some potential assembly issues while putting it together. The instructions are pretty straightforward, but I feel that some of the drilled holes are not quite accurate, or the screws don’t seem to lock properly. My question is: what is the best way to handle assembly problems with the Ikea BRIMNES? Are there proven methods to identify and fix these issues, or to involve Ikea if needed? I want to avoid having weak points or compromising the stability after assembly. Looking forward to your experiences and advice!
One more point: Make sure to tighten all screws with the appropriate tool, neither too loose nor too tight. Over-tightened screws can damage materials or reduce holding strength. If a part does not fit properly, also check whether you may have accidentally used the wrong screws.
Alberto5119 Feb 2018 14:45I can empathize – assembly issues with furniture are really frustrating. It’s important not to get stressed if something doesn’t fit. Most of the time, there is a solution; you just have to be patient. In such situations, you can also contact Ikea customer service politely to request an exchange or advice. They are usually very understanding.
For a structured approach: First, check the parts against the assembly instructions for completeness and quality defects. If an assembly error is identified, it is advisable to contact customer service with details of the affected components. For minor deviations in drilling, making independent modifications is not recommended, as this may void the warranty. If manual adjustments are made, they should be carried out with great care.
Gino38 schrieb:
If the drill holes don’t line up, sometimes you can carefully adjust them with a small Phillips screwdriver, but only if you have experience. Thanks for the tip, that sounds practical. My concern is that even small misalignments on load-bearing parts could later affect stability. Would it be better to avoid this with the Brimnes model and insist on replacement parts instead?
pefopo schrieb:
My concern is that even small misalignments in load-bearing parts could affect stability later on. That is absolutely correct. In general, I recommend replacing load-bearing elements first. Reworking with tools is more suitable for simple surfaces or optional components. Especially with wood-based materials, such as those used in BRIMNES, stresses from incorrect drilling can cause problems.
If something gets tricky during assembly, just take a moment to breathe and have a short break—it works wonders! Afterwards, with a fresh mind, you often spot the simple mistake you missed before. And dealing with escalations at Ikea usually goes smoother if you stay polite—it saves a lot of stress.
