ᐅ Which Malm replacement parts fail most often?
Created on: 9 Dec 2021 18:23
Floru9
Floru9
9 Dec 2021 18:23
I use several models of Malm furniture, mainly dressers and cabinets. I have noticed that some replacement parts tend to break more often than others. Therefore, I am interested in knowing: which Malm replacement parts fail most frequently? I am especially looking for experiences about which components show wear or become defective most quickly with daily use, such as specific drawer slides, inserts, handles, or other elements.
I would find it helpful if you could describe your observations as specifically as possible, including whether the issues are due to stress, installation, or material quality. Maybe you also have tips on how to minimize wear and tear. Thanks in advance for your contributions!
BOSULE
9 Dec 2021 19:08
In my experience, the guide rails of Malm dressers are most commonly affected. In particular, the metal drawer slides tend to jam or have small wear parts break with frequent use. This is often due to insufficient lubrication or slightly imprecise installation.
Another issue concerns the handles, especially on older models – the screws can loosen and may break or pull out if subjected to excessive force.
Tips to reduce these problems: regularly check if the screws are loosening and lubricate the guide rails with fabric softener spray or silicone spray.
kaju67
9 Dec 2021 20:14
BOSULE schrieb:
the sliding rails of Malm dressers are most often affected
I agree with that! Sometimes my drawers stick or grind when they don’t slide smoothly anymore. A little WD-40 here and there often works wonders :-)
Also, the drawer hinges on my Malm cabinets have lost some functionality after a few years. Not dramatic, but noticeable. I think these small parts are often underestimated, and that’s where wear and tear shows up pretty quickly. 🙂
kloreo
10 Dec 2021 09:17
The most common parts to break are the drawer slides, as the rollers inside, which are made of plastic, wear out quickly. Handles rarely break; usually, only the screws become loose.
Laurence
10 Dec 2021 11:05
I would like to add that, in addition to the drawer slides, the shelves in Malm furniture often cause issues. These are frequently made of particleboard and can quickly warp or break when overloaded or exposed to moisture. Furthermore, the screw connections between the shelves and side panels are often a weak point, as the materials can degrade over time.
It is also regularly recommended not to overload the drawers to extend the lifespan of the sliding mechanisms. Careful installation and regular checks of the screw connections also have a positive effect on durability.
puvin
10 Dec 2021 14:42
Absolutely! Especially for the guide rails, a bit of lubrication is worth its weight in gold and significantly extends their lifespan. And folks, don’t forget – close drawers gently 🙂!
Another “highlight” for me was the fastening clips for the back panels, which tend to come loose easily. It’s not a major issue, but it’s annoying when the back panel wobbles. A small strip of cardboard or a drop of glue usually works brilliantly to fix that!
