ᐅ Which types of flooring are recommended for single-family homes? What does the building expert community suggest?
Created on: 14 Sep 2020 07:43
exto1791
We are slowly starting to consider the flooring for our planned single-family house and are still completely undecided.
We have an open-plan living-dining area with a kitchen. We believe that a seamless floor transition looks nicer than separating the kitchen from the living/dining area. For this reason, we want to have a uniform floor covering throughout.
Now the question: vinyl or tiles? We have already read about the pros and cons, but maybe we can get some first-hand tips or tricks here that might put some of the disadvantages into a more positive perspective?
1. Question: Is vinyl really safe to use in the kitchen? Is vinyl fully waterproof? How does vinyl flooring react if, for example, a knife slips from my hand and falls on the floor? Will I get immediate dents or marks? Are there vinyl floors that are significantly more resistant?
2. Question: How does vinyl respond to sunlight? Since we will have several large glass fronts in our living-dining area, vinyl "technically" seems to be excluded... Does vinyl actually deform? Is it true that vinyl, like parquet, fades significantly in sunlight?
3. Question: Is vinyl really only suitable for 10-20 years? What happens afterward? Do I have to replace the vinyl, or can it be refurbished or maintained?
--> We are considering tiling the entire area because then we would be "done," have a robust floor that works perfectly with underfloor heating, is simple, and very resistant to sun/fading/stains/impacts. We think generally that you can’t go wrong with tiles.
However, I see the problem that the tiles will likely stay in place for a lifetime, and I may not want or be able to replace them later due to the high effort involved. Also, any chip or damage to a tile will be visible for life since I can’t quickly repair it (true, vinyl also can’t be easily repaired, but I could replace the floor after 15-20 years). Another downside is cost. Tiles are generally more expensive, and I wouldn’t be able to install them myself (I don’t feel confident with tiles but feel okay with vinyl), so we are wondering what is best for us.
What flooring have you installed in your living/dining areas? What good or bad experiences have you had?
Now about the upper rooms:
1 bedroom and 2 kids’ rooms: vinyl/parquet/cork/laminate?
We are familiar with the pros and cons here as well. Parquet is "technically" out of the question because it is very expensive (is there good parquet for around 30€ (about $33)?). Opinions on vinyl are divided... We also have clear concerns (especially in the kids’ rooms) regarding plastic flooring... Are they really completely safe and non-toxic nowadays? If I pay attention to this, can I safely choose vinyl for the kids’ rooms? The kids’ rooms should be "good and affordable" above all. Cork might be an option? Laminate is somehow excluded because it is very noisy and offers no advantages over cork or vinyl.
Is parquet sensible for the bedroom? Here there is no fading, parquet is durable, and sunlight is limited. Very durable and might make the bedroom more visually appealing. What do you think?
We are open to any suggestions.
Where did you buy your flooring? From a hardware store? A specialist dealer? Are there recommendations, including manufacturers or models?
nordanney
14 Apr 2021 15:22
Tolentino schrieb:
Definitely something to consider for the kids' rooms/bedrooms.
Especially with kids, I don’t want them playing on plastic. Every toy is scrutinized for how eco-friendly it is, and then the children end up playing on cheap plastic...
exto1791 schrieb:
- Hardwood flooring looks great, relatively high quality, but probably not the best choice for kids’ rooms
It works very well. Just make sure it’s not a soft wood. You can get oak engineered hardwood boards starting at 20€ per square meter (around $20 per square foot). The manufacturer doesn’t matter.
exto1791 schrieb:
How “difficult” is it actually to glue down hardwood flooring yourself? It’s often recommended for underfloor heating…
It’s much easier than laying tiles. The adhesive comes pre-mixed, you apply it to the floor, then lay down the (usually click-lock) hardwood boards. Afterwards, you weigh it down with heavy buckets (at first you can use the unused adhesive buckets, later water buckets work well) to ensure a strong bond between the wood and the subfloor.
netuser
14 Apr 2021 15:28
exto1791 schrieb:
My main concern is the kids’ rooms... I think it might be more comfortable for children to play on cork/vinyl flooring than on hardwood... But as I said, we still don’t really know what we will decide... 🙁
Save yourself the hassle and all the effort!
1. Different materials
2. Different heights
3. Transitions between rooms
4. More waste
5. Probably little to no price difference...
Install a high-quality flooring (hardwood) all at once, treat yourself and the kids to the comfort, and avoid the disadvantages mentioned above.
SamSamSam
14 Apr 2021 15:30
nordanney schrieb:
I definitely don’t want kids playing with plastic. For every toy, I consider how eco-friendly it is, and then the kids end up playing with cheap plastic...
My kids won’t be putting the floor in their mouths either (at least I hope so) 😀 so naturally, you pay a bit more attention to these things. But to rule out vinyl as cheap plastic... I think there are quality differences between manufacturers/products there as well 😉
tumaa
14 Apr 2021 15:30
exto1791 schrieb:
My main concern is the children's bedrooms.
By "bedrooms" I meant all sleeping rooms... I would possibly add a play rug as well.
saralina87
14 Apr 2021 15:34
SamSamSam schrieb:
My kids wouldn’t put the floor in their mouths either (at least I hope not) 😀 so you naturally pay a bit more attention to these things. But to rule out vinyl as cheap plastic... I also believe there are quality differences between manufacturers/products;)
My child regularly licks the floor.
No idea what fascinates her about it, but not a speck of dust is safe here.
SamSamSam
14 Apr 2021 15:39
Oh, okay, I’ll have to rethink that then 🤨. I’ll better order 2-3 samples to see what tastes better for mine, in case they eventually develop a taste for it. 😀 They’re still young, you never know.
