ᐅ Which types of flooring are recommended for single-family homes? What does the building expert community suggest?
Created on: 14 Sep 2020 07:43
exto1791
We are slowly starting to consider the flooring for our planned single-family house and are still completely undecided.
We have an open-plan living-dining area with a kitchen. We believe that a seamless floor transition looks nicer than separating the kitchen from the living/dining area. For this reason, we want to have a uniform floor covering throughout.
Now the question: vinyl or tiles? We have already read about the pros and cons, but maybe we can get some first-hand tips or tricks here that might put some of the disadvantages into a more positive perspective?
1. Question: Is vinyl really safe to use in the kitchen? Is vinyl fully waterproof? How does vinyl flooring react if, for example, a knife slips from my hand and falls on the floor? Will I get immediate dents or marks? Are there vinyl floors that are significantly more resistant?
2. Question: How does vinyl respond to sunlight? Since we will have several large glass fronts in our living-dining area, vinyl "technically" seems to be excluded... Does vinyl actually deform? Is it true that vinyl, like parquet, fades significantly in sunlight?
3. Question: Is vinyl really only suitable for 10-20 years? What happens afterward? Do I have to replace the vinyl, or can it be refurbished or maintained?
--> We are considering tiling the entire area because then we would be "done," have a robust floor that works perfectly with underfloor heating, is simple, and very resistant to sun/fading/stains/impacts. We think generally that you can’t go wrong with tiles.
However, I see the problem that the tiles will likely stay in place for a lifetime, and I may not want or be able to replace them later due to the high effort involved. Also, any chip or damage to a tile will be visible for life since I can’t quickly repair it (true, vinyl also can’t be easily repaired, but I could replace the floor after 15-20 years). Another downside is cost. Tiles are generally more expensive, and I wouldn’t be able to install them myself (I don’t feel confident with tiles but feel okay with vinyl), so we are wondering what is best for us.
What flooring have you installed in your living/dining areas? What good or bad experiences have you had?
Now about the upper rooms:
1 bedroom and 2 kids’ rooms: vinyl/parquet/cork/laminate?
We are familiar with the pros and cons here as well. Parquet is "technically" out of the question because it is very expensive (is there good parquet for around 30€ (about $33)?). Opinions on vinyl are divided... We also have clear concerns (especially in the kids’ rooms) regarding plastic flooring... Are they really completely safe and non-toxic nowadays? If I pay attention to this, can I safely choose vinyl for the kids’ rooms? The kids’ rooms should be "good and affordable" above all. Cork might be an option? Laminate is somehow excluded because it is very noisy and offers no advantages over cork or vinyl.
Is parquet sensible for the bedroom? Here there is no fading, parquet is durable, and sunlight is limited. Very durable and might make the bedroom more visually appealing. What do you think?
We are open to any suggestions.
Where did you buy your flooring? From a hardware store? A specialist dealer? Are there recommendations, including manufacturers or models?
Martial.white14 Sep 2020 18:23Flocko1 schrieb:
I’ll just throw carpet into the mix... Out!
nordanney schrieb:
What defines "really good hardwood flooring"? Who in their lifetime will sand their hardwood floor twice—probably no one. And oak is oak. The price differences come a) from the brand name (like with Apple) or b) from special finishes (well-aged, smoked, and treated with 5,000-year-old Inca oil) or dimensions.
Otherwise, you can get really good hardwood flooring for around 25–35€ (about 27–38 USD). Also, for example, whether there are many knots in the wood (wood grading). Then there is the thickness of the wear layer, which is not only important for sanding but also helps absorb impacts and scratches better.
nordanney schrieb:
However, a tipped-over bucket or an open window is absolutely no problem, as long as the flooring is glued down and not standing in water for hours. Here, the thicker the wear layer, the longer it takes for moisture to reach the swelling substrate layer. And the less chance the substrate has to push up the wear layer, which results in unsightly moisture damage.
It might be possible to get good hardwood flooring for 25–35€ (about 27–38 USD), but I claim this is not the rule. I usually see flooring with a maximum wear layer thickness of 3mm (about 0.12 inches).
That’s what I have now, and it’s not good. Just dropping a pair of scissors can leave a deep dent all the way into the substrate layer. And I have Bembé oak hardwood flooring.
8mm (5/16 inch) solid wood. No fancy floorboards, then it’s affordable.
I had carpet. Over time, cleaning became a problem. Furniture left marks, and the sun caused some fading.
With shampoo and carpet cleaner, it worked quite well. It’s more labor-intensive than a damp cloth.
I think a lot depends on the quality of the material and the installation, no matter what you have.
In our rental apartment, the laminate was very prone to scratches and had water damage. The installation had wide gaps.
Tolentino schrieb:
It might be possible to get good hardwood flooring for 25-35 EUR. However, I argue that this is not the norm. I usually see flooring with a wear layer of only up to 3mm (about 0.12 inches).A wear layer of around 3.5 to 4mm (about 0.14 to 0.16 inches) is normal and completely sufficient. You’ll find that even from standard engineered hardwood flooring manufacturers in the price range of 100 EUR and above. If you want a thicker wear layer, you might as well go for solid hardwood.nordanney schrieb:
That is normal and completely sufficient. As I said, unfortunately not in my case.
Maybe there is some compensation I’m missing, or it depends on how old the timber was, or who knows.
nordanney schrieb:
If you want it thicker, you might as well go solid wood. I also think that would be best. And then solid wood all the way.
I don’t read 10 pages in a forum when I’m on vacation, so here’s a quick and concise answer:
Yes! Bamboo flooring!
exto1791 schrieb:
is there good parquet flooring for 30€??).
