ᐅ Which type of flooring is suitable for the upstairs hallway with a beech staircase?
Created on: 22 Oct 2020 11:55
Renovierung20
Renovierung20
22 Oct 2020 11:55
we are currently renovating our house and are considering possible flooring options for the upstairs hallway.
The hallway is accessed via a beech staircase. Four rooms open off the hallway: two of these rooms have laminate flooring in a light oak finish. The bedroom is carpeted in a light beige color. The bathroom has light gray tiles with a stone look.
At the moment, the hallway has a dark brown vinyl floor. Could you please give me advice on which color or wood-look vinyl flooring would best match without clashing with the laminate and the beech staircase?
Many thanks to you all!
Wintersonne
22 Oct 2020 15:56
Why do you want to install vinyl flooring again? Is it because of the same height? I would compare either the light beige carpet or the same laminate. A fourth type of flooring would be too visually busy for me.
Renovierung20
22 Oct 2020 15:59
Yes, partly because of the height (which is why we chose vinyl) and also because we no longer have the carpet or the laminate flooring (both were installed about 1-2 years ago)...
Mycraft22 Oct 2020 20:18
Just continue with beech...
Wintersonne
22 Oct 2020 20:28
I wouldn’t go for a wood look. Something relatively monochromatic/subtle, maybe in a tone similar to the tiles? Or if you want to be bolder, something like Travertine Strong Gerdoo. It also depends on your interior design style.
HausiKlausi25 Oct 2020 23:01
Why not use wood (plank) to connect to wood (beech)? Admittedly, I am a bit biased—I really can’t relate to vinyl or so-called "design flooring" at all.
