ᐅ Which fastening methods are the most secure for IKEA Platsa?
Created on: 10 Feb 2020 09:12
Rineo
I am currently planning to assemble an IKEA Platsa cabinet system in my living room and am focusing on which fastening methods are the most stable for Platsa. My goal is to create furniture that is as durable and secure as possible, especially when combining multiple modules. I am interested both in the connection methods recommended by IKEA and in additional measures suggested by experienced users. Are there any experiences or tips regarding which screws, wall plugs, or other fastenings are the most reliable? What importance does wall mounting have, and are extra locks or fasteners between the individual cabinet elements advisable? Thanks in advance for detailed advice and any personal experiences!
Rineo
11 Feb 2020 10:05
Laukau5 schrieb:
One question for you: What type of wall do you have, and how many modules are you planning to connect?
Thanks for the advice! I have a solid brick wall, and I plan to combine the modules into a large sideboard made up of 4 individual units. It should stand fairly securely against the wall and be somewhat load-bearing, as I want to store books and devices inside.
I will definitely use stronger screws and the appropriate wall anchors. Are there any additional recommendations regarding screw thickness or length that are particularly well-suited for these types of brick walls? Also, I’m interested in whether it’s worth using any special connection methods in addition to the cam lock fasteners, such as metal brackets or similar, to better resist lateral forces.
O
onron
12 Feb 2020 07:55
Regarding the brick wall type, I can tell you the following:
For wall fixing, heavy-duty anchors (metal expansion anchors) are best suited, as they provide high load capacity and are ideal for solid substrates such as brick or concrete.
- Screws with a diameter of 5–6 mm (0.2–0.24 inches) and a length of at least 50–70 mm (2–3 inches), used together with appropriate anchors, will give you a secure hold.
- In addition to cam-lock connections, using metal brackets at the module edges is worthwhile, as they absorb additional lateral forces. This increases the torsional stiffness of the entire structure.
- When installing on the floor, make sure all modules are aligned flat to avoid warping.
Overall, I recommend combining different fixing methods: cam-locks for panel connections, heavy screws with expansion anchors for the wall, and supplementary metal brackets for increased rigidity.
This results in a solid and durable construction.
