We are currently trying to decide which type of facade construction is preferable. The two facade options are as follows. It is assumed that the costs are the same, and any gains or losses in space can be neglected. The focus is solely on the advantages and disadvantages of the facade construction itself.
1.) 17.5 cm (7 inches) Poroton, mineral wool insulation, facing bricks. Total construction depth 44 cm (17 inches)
2.) 36.5 cm (14 inches) Poroton, brick slips. Total construction depth approximately 38.5 cm (15 inches)
In both cases, the result is a KfW 55 standard.
Is it possible to determine which construction is more valuable? Please explain.
Ralf
Ralf
Alex85 schrieb:
You know exactly what is meant.I wasn’t asking what the term means according to the standard definition 0815 for how a term should be understood, but rather what the original poster (OP) means when they say they are not planning “these collectors.”
I had to look it up myself to find that there is a differentiated terminology where collector panels are sometimes called collectors and sometimes modules depending on their design and purpose. In everyday language, I know both types are referred to as “collectors.” And what they have in common is that they are “blue and architecturally foreign objects on the roof” — that is what prompted my question to the OP. It was not intended as idle chatter for other participants.
So, fine, I learned something new again. You find similar cases with terms like knee wall and dwarf wall, or dormer and cross-gable (and also with pantry and pantry — once in the classical, once in the more modern sense).
What is important (to avoid misunderstandings) is that people exchange what they understand by the terms, not whether somewhere it is written who uses the more correct term.
RobsonMKK schrieb:
Do you complain when people colloquially say "Drempel"?No. I point out the difference (and its potential for misunderstanding) and explain it. When writing, dialect doesn't come through because the filter for "north-south differences" in terminology doesn't activate. There are no official penalties for that in Flensburg either.
